Flexeel air hose
Flexeel air hose
Flexeel air hose
Patrick Capobianco
>I'm not sure which diameter hose to get the 1/4" or the 3/8". Would I notice the difference between the to? It would be for nailers, etc.
Re: Flexeel air hose
Larry in NW Ohio
>Patrick For what it`s worth, in my opinion the 1/4" would be plenty because air nailers are not a big volumn air user like an air sander would be. Also you aren`t dragging around a bigger 3/8 hose, which after awhile will get to be a PITA, it`ll also get heavy. Larry in Ohio
Good advice
Rick L
Re: Polyurethane hose is best *LINK*
Rick L
>Get the 3/8" polyurethane hose. It isn't noticably heavier and it can make a difference over 1/4" in other applications. Northern tool has the best price I've seen. Poly hose stays flexible in the cold and is so much lighter than any other hose.
get this
Bob Reeve
>Let me start this by saying I work for Coilhose, the mfg of Flexeel. I sell a ton of it and most is 1/4" ID. In actual use, the only time you would need the 3/8" is if you are using either a sander or using a nail gun for shear wall. Even framers who use big guns have switched to 1/4". It will not starve the gun.
On another note, Flexeel is made in Oregon with US materials. It is also has reusable ends, not permantly attached ends like the Chinese imports from HF and others.
I know I am biased, but even with the multitudes of copy cats, our sales continue to rise dramatically every year.
Bob
