DC switch question
DC switch question
DC switch question
>I have the Long Ranger blast gates on my DC that have the micro-switches on them. The one on my TS seems to have gone bad (won't turn the system on) and the one on my BS is glitchey. Have to poke it with a sharp stick to get it going.
Anyone else have these switches? Yours holding up? Any suggestions for replacements or improvements.
Re: DC switch question
del schisler
>I dont have the automatic blast gates I have the manual gates The only ploblum i have is saw dust of small chips getting to the end that close's Cips get's lodged in the end and wont let it seal good I made a tool from a screw driver I ground the end down flat and bent it at a angle and small so that i could get into the plastic real good and get the debree out Their maybe some in your gates???
Larry in NW Ohio
>Barry Do you have a pic of the switch, I have quite a few small switchs that would probably work. I get them off junk microwave ovens, your more than welcome to a couple if they would work. Larry in Ohio
Ray Thompson
>Could be dust in the micro switch. I have had this problem on equipment that I serviced at one time. Have you tried cleaning them?
Ray Thompson
>Del I went through the same thing with the manual gates. There are two fixes that I learned from others. Drill a 1/2" hole right at the corner or simply cut the corners off at 45 degrees. It doesn't affect the vacuum and stops the clogging. I drilled the holes. On the rare occasion that it does get clogged it's really easy to clean out.
>Barry I worked on a lot of electronic equipment over the years and micro switches are notorious for going bad. They are very hard to repair, trying blowing them out with an air compressor but the best bet is just to replace them.
New Info on question/ Question?
>I just went and fiddled with the switch on both the BS and TS. There are short leads that appear to be soldered to the terminals on the switches. If you fiddle around with the leads, the switches go back to work for a minute or two. Clearly something has happened with the connection. Seems odd. Basically the wires sit still and are not even dusty. What would break them? Any suggestions? I am not an electronics guy. Would it make sense to eliminate the short leads and solder the wires from the DC directly to the switches?
Could also be
Dan Donaldson
>If the actual connections look OK, then it is likely that it is the switch. The lugs on the outside that the leads connect to usually are directly connected to the mechanism inside the switch. When you wiggle them, you are actually moving the internals of the switch and that can sometimes make it work. The solution in this case is probably to replace the switch.
Barry, Question for you...
Jim Rahbe, Bedford, TX
>Barry,
What type of connections do you have now between the �short leads from the switches� and the Long Ranger control head? If this connection is soldered, then I agree with Dan, it is most likely the micro-switch itself. If the connections are simply twisted together than I�d be looking there first.
You can�t really tie your DC directly to these small switches. All they do is provide a low voltage signal to the control head telling it one of the gates is open. The control head then applies the 115/220 VAC to the DC to turn it on.
Jim R.
Re: Barry, Question for you...
>The short leads are stranded copper and so are the wires that run to the Remote switch for the DC. They are very well twisted and then bound with a wire nut. I removed the wire nuts and touched the wires together. The DC ran.
I was trying to figure out is somehow the short leads had broken. I could eliminate them by tying the Wires to the controller directly to the switch. That would eliminate the wire nuts and the short leads.
And I understand that this is a low voltage system and that these switches will not control the DC directly.
Just making sure...
>Well, then, it appears to me that you and Dan have troubleshot it down to the micro switch itself..
My comment about wiring direct to the DC was based upon your statement �Would it make sense to eliminate the short leads and solder the wires from the DC directly to the switches?� I figured this is not exactly what you meant, but wanted to make sure..
Jim R.
del schisler
>i have been in repair for 50 yrs And have came up on lot's of switch's like that I would just replace Most contact's are not all that good inside If you had some good contact cleaner Just spray the switch where the flat piece and the wire's are soldered Some may get inside I have done this and have some short time fix Just get a new one I dont like radio shack go and see what they have
