Recommendation re: Vacuum Bag Veneering Pump
Stephen Roth, Chatham NJ
>I am looking for a good quality pump for vacuum bag veneering. (Priced in the under $500 range.) Any recomendations would be appreciated.
Re: Recommendation re: Vacuum Bag Veneering Pump
Mike Foydel
>Surpluscenter.com
They have the Gast Rotary vane pump that sells elsewhere for around $400.00 for $89.00.
It's 220 volt but they sometimes have 110.
Mike
You might also try *LINK*
Mike from St. Clair Shores
>Here's a link with some good info.
Joewoodworker
Terry in Edmonton
>I second the surplus Gast recommendation. I have a 220V one and it works great. If you get the oiless carbon vane version make sure you go the Gast site and get the maintanence instructions. Mistakes made here will cost you $75 for a new set of vanes. These are the better version because they are continuous duty (24hr/day 365day/yr).
I prefer the piston type.
Keith Newton
>I have two piston pumps from old grocery refrigeration units, and a gast rotary vane, that I have not used in ten years, which I would sell cheap. I tried putting a muffler on it, then I tied a pillow around that, but it was still too noisy for me.
Matt Robinette,Mt Juliet Tn
>I bought the venturi v2 kit from joewoodworker.com. In fact I just loaded a bag about 2 hours ago and it is in use right now. Works great.
Matt
There is one great place *LINK*
Felix B
>Joe Woodworker - My entire setup cost around $350 - it included a bottle (quart for starters) of glue, veneer saw, glue rollers, vacuum bag (2"x4"), etc.
Also, the service is exceptional.
http://www.joewoodworker.com
