Exposed wood - marine question?
John Uteck
>A friend has a mahogany boat stored outside on the SC coast. The boat had been covered, but is generally exposed to the elements. The varnish has pretty much deteriorated and flaked away. His major concern is the deck boards at this time, and he is looking for a quick "rejuvenation" to help keep the wood protected until he can re-finish it entirely. Indoor storage is not an option. He is wondering if there is a quick oil finish or penetrating sealer that he can use that will help protect the wood from the weather and salt air at the present time. Any suggestions that will hold up to the salt air in the interim?
Thanks.
Re: Exposed wood - marine question?
Rob Stokes in North Vancouver
>The short answer is no.
Application of linseed oil (BLO) will act as a weather deterrent for a short while, but it will also attract mold which in turn will discolor the wood. The market is full of teak oils etc. that are basically tung oil with color and other varnishes added, and these might also hold off the elements for a while, but they too would only be temporary and would not provide any real protection. There's also "wonder sealers" being marketed out there that are epoxy based and while these can be worthwhile to apply, they degrade in UV light (quickly). Then there's the whole "epoxy on a wooden boat" argument - I'm not going there!
Unfortunately the only way to guarantee decent protection from the weather is to do it right and refinish the brightwork. If he's really stuck, he may want to purchase the actual finish he intends on using to redo the finish properly and make up a small batch of wipe-on with it (thin the varnish with up to 30% thinner - no more). He should them scrape off all the big pieces and at least assure than any film finish remaining is still adhered to the wood. Then he can apply the thinned finish with a rag or brush. The thinned finish will tend to wick under the old finish and seal it off and the exposed wood will also receive a thin layer of protection. When that coat dries, apply another one that's not thinned so much (if at all).
Keep in mind that if he does this, the boat's still going to look like crap, but it should buy him a bit of time.
Rob
Mike from St. Clair Shores
>One of the best that I found when I owned a big cruiser that had teak everywhere was a product called SIKKENS. I think Boat U.S. carries it. I think it best to prepare the surface before applying, Here in Michigan any boat worth anything is shrink wrapped for the winter. I'm getting anxious to pull the wrap off and get out and do some fishing. I'll never own another boat with exposed wood. the upkeep is way to much work. The area I live in is made up of thousands of boaters and in all my years boating I've talked to alot of captains who agree about SIKKENS.
Mike
Easy,
Garrett in Victoria BC
>Hi John
I'm a life-long boater, sail and power. Current boat has zero exterior wood for the obvious reason.
However...
For a quick, effective, and inexpensive fix, here's an article I wrote 7 years ago for Pilothouse Online
Cheers, Garrett
"Not for Teak Freaks"
A few years ago, I finally tired of cleaning and re-varnishing the
so-called "bright work" on my boat every year. "Bright" obviously does not
apply to those of us who labour long and hard to keep marine teak looking
like indoor furniture. Yet, I couldn't bring myself to leave it flaking
where the varnish was trying to hang on, and dirty grey where it had
departed. But that's exactly the condition it was in as I kept putting the
job off in favor of other chores.
One of which was putting a coat of semi-transparent preservative on the
cedar siding of my cottage. I had just finished when I looked out at my
boat and had the proverbial light bulb go on.
Both cedar and teak contain natural oils that continue to leach out almost
forever. That's what makes them such terrific woods for outdoor use when
left unfinished. It's also one of the two reasons that varnish and
polyurethane don't last very long on either wood. They lie on the surface,
and the leaching oil lifts them from within while the sun's ultra-violet
radiation, acid rain, etc., etc., beat on them from without.
However, the cedar siding preservative had endured the same conditions on
my cottage for several years, and although I had given it another
application as preventive maintenance, the original still looked okay. The
best part was that no preparation was necessary. I just slathered on
another coat. It has a consistency not much heavier than water, so it's
really easy to apply, but watch the runs. The first time around, the cedar
had drunk that stuff at an amazing rate. This time, the original 2 coats
had effectively sealed the wood so all that was going on was another
surface coat, i.e. no absorption.
By the way, this was a house-brand preservative that only cost about $15
per gallon at a discount outlet, but for those who want to pay more, a
similar product is available at higher prices from any major paint
supplier. Basically, it's just clear oil with two added components: dryers
to ensure that a hard surface forms quickly, and a bit of teak-like color
to provide protection against UV rays. The key to getting close to a
natural looking finish is to buy the semi-transparent product, not the opaque.
I reasoned that if it did such a good job on the very porous, soft cedar,
why wouldn't it work just as well or better on tight, hard teak? I decided
to find out.
Back on the boat, I stripped what was left of the old varnish, and cleaned
and sanded the teak one last time. Then I gave it 2 coats of the
preservative with about 12 hours in between. On a roll, I even put it on a
couple of heavy wear areas including steps. The result looked like a piece
of semi-matte Danish furniture. Since the stuff seals the pores effectively
and is petroleum based, masochists determined on a high gloss finish could
probably lay on a coat or two of varnish or poly within 12 hours of the
last coat of preservative. (Check with your supplier on compatibility.)
Weathering will undoubtedly remove the varnish almost as quickly as normal,
but replacing it should be a lot easier since the underlying preservative
should keep the teak in good shape.
The big question now was whether it would stand up on a boat that sat out
on a mooring all summer, and was laid up exposed to weather all winter.
Three years later, I sold the boat. The buyer commented on the good
condition of the teak, including the steps. He simply wouldn't believe me
when I told him that I had not touched it again since that first
application of cedar preservative.
The stuff works. Whether it's for your boat depends on you. Because it
contains some color and dries to a semi-matte luster, it is not going to
look like clear varnish. However, the labor and dollar savings are
tremendous, and my results drew lots of cheers and few jeers. The product
is so cheap that before you strip, clean, sand, and varnish again this
year, buy a can of preservative, try it on a test piece of teak, and decide
for yourself.
