APB!! Tool missing. Check the milk cartons...
Rod Peterson -- Ormond Beach
>A year or so ago, someone wrote me asking about the zero clearance insert Norm uses (the one with the replaceable insert—see pic). I can't remember what I answered exactly, but probably something along the lines of they're all over in the woodworking stores, which ten years ago, they used to be. I hadn't looked at/for one in a long time, because I felt they were a little rich for my blood, and in any event, they wouldn't fit a Craftsman saw, which for most of those ten years was what I had.
Recently, however, I started looking around, just for kicks, and do you know that I can't find those things anywhere? Does anyone have any idea what happened to them? I suspect some manufacturer of a competing version might have bought them up and taken them off the market (that happened to a ham radio product I own once). But, hey, that's just the cynic in me.
Here's the pic I've been using on my Norm's Tools site for some time:
Norm discussed it at length in his Table Saw 101 episode (just aired here) as if it was still widely available. Some people are going to be disappointed, I fear.
Any information or ideas greatly appreciated.
Rod
P.S. Ask Lee Schierer about the gorgeous one he made for his saw. I saw it at 5-Barns a couple of years ago, I believe.
Re: APB!! Tool missing. Check the milk cartons...
Ray SW Ohio
>I haven't looking for one in a few years. Too expensive for me too. Cheaper to make my own.
Type t oo fast and click too fast
Ray SW Ohio
>Should of said been looking
Stuart Hough
>I saw one in the Woodcraft store outside of Charlotte, NC last year. I tried to wrangle it to the car, but my buudy the WALLET wouldn't hold his end of the rope. The darn thing got away and hid back on the shelf! I believe it was for a Jet or Powermatic machine, which might explain why it fought so hard, seeing as how I'm such a low-cost (cheap) shopper.
Larry in NW Ohio
>Rod they have them in Eagle America catalog on page 56 in the SEPT. 2006. I`ll keep looking in my other catalogs if this isn`t what you want. Larry in Ohio
Larry in NW Ohio
>I also just looked online, it`s number 400-1090 at EagleAmerica.com
Da source
Randy Johnson Connersville, IN
>Initial cost is high but the inserts are cheap enough that it beats making my own.
http://www.pacifier.com/~wood/models.html
Nope.
>That's the Betterly Tru-Cut (the same one Bart Goldberg suggested in a separate thread just above)—not the same. They're the ones I'm suspecting might have bought out the others.
Thanks, though.
Rod
Yep.
>Those are the ones. I wonder why they don't have decent pictures.
I also wonder why they're so hard to find. And, as I said originally, I wonder why they've virtually disappeared from the stores after having been all over the place years ago.
Thanks.
Rod
Marsh Pronneke
>Heck Rod, I didn't even have to check to "Milk Carton" I just checked "QRZ" to get the rest of the story! Sounds intresting, I have several of the same hobbies as well.
73's Marsh
The rest of the story…
>I've had the shack in storage and been off the air since early '98, so I'm having trouble remembering the name right now (aha!—found the file folder), but in the early '90s (must have been Fall of '92) a couple of guys in AL developed a remote coax switch control (DX Solutions SA6) which not only had push buttons for manual selection, but would also read band data off transceivers equipped to provide it (like my TS850). The instant I saw the ad in QST I phoned in my order, as I knew I had to have that. There was nothing like it on the market (there were remote coax switches, but not automatic).
It turns out they were at least a couple of months premature in placing that ad, as they wound up having to get UL testing and listing and had to jump through a couple of other hoops that they didn't anticipate. Anyway, that's not the real story. I got the unit in Feb, '93, and wired it into the station (I was switching a single feed of 50 ohm hardline to a TH6DXX for 10, 15, and 20—a Cushcraft A4, also on 10/15/20—a KLM rotatable dipole on 40—an inverted V on 80—a half sloper on 80—and an inverted V/lazy S on 160. It was amazing to change bands on the '850 and have the correct antenna come up automatically.
When I got my Alpha 87A, I was essentially fully automated, including keyboard control of the '850 through either TRLog or LOGic (my regular logging program). All I had to do was type in a frequency, the '850 would jump to it, switching the antenna, and as soon as I keyed the rig the Alpha would follow. I even had a Heathkit rotor controller that was nearly automatic—just type the prefix of the station I wanted to work and the rotor would turn to the proper azimuth.
I never thought much more about the DX Solutions guys until I ran into a doctor from MN (I've forgotten his call) at the NIDXA DX convention who was turning into a big time DXer and contester. He, too was an early adopter of the SA6. I later saw him running ads trying to buy some more of them (he was building a super station). I asked him about it and he told me that the guys in AL had sold the controller to Alpha (who, you may recall, marketed their own remote relay controller driven by the auto bandswitching '87) and they promptly set it on the shelf, promoting their own unit—which, by the way, wasn't nearly as good. This insert story smells like the same thing.
Apparently there were only about 119 of them manufactured. So, once I get all that stuff out of storage, looks like I may have some gold in those boxes.
Rod
K4QG
Edward in Vancouver
>Thumbing through my L.V. "February 2007" catalouge, I see something very, very similar to it on pg. 28., described as the "Tri-cut zero clearance throat plate,Product # 46j85.10 made of 7/16" aluminum with a replaceble phenolic insert(not wood). Seems they have models for Delta, Crafstsman/Rigid, and most of the other popular saws. Price is CDN $89.00 and replacable phenolic inserts are $21.50.
Me, I found that the left-over t&G Oak hardwood flooring scraps from when we did the living room are exactly the same thickness as the throat plate on my Delta. I just cut the flooring scraps to rough size, screw the Delta plate ontop of it, and shape in on my router table with a bearing flush cut bit.
So are you looking for one?
John in New Mexico
>or just commenting on its passage? I bought one of those at Woodcraft when they carried them. Fought it off for years, as its soooo much cheaper to make them out of scrap, but then realized that the homemade ones caused me more trouble than the money they saved was worth. Anyway, I love the aluminum one. I made some new inserts out of UHMW plastic, though next time I'll probably make them out of wood. My only complaint was there's nothing on the back to keep the plate from flipping out of the table top if a thin piece of wood drops into the front of the insert when the blade is running. Easy fix though, 8/32 cap screw in the back.
John
Just idle curiosity…________
Dave Arbuckle, Plano, TX
>The local Woodcraft has replaced them with a similar product from a different manufacturer (durned ugly thing it is, too). The attraction from the store's POV is that the newer product has a one-size-fits-all insert, where the Norm-style (or as I call them, Dave-style) one needs a different insert for pretty near every different saw (as well as a different body of course, no getting around that.)
My Ridgid uses one that is listed for a Craftsman saw, but perhaps your model used a different size? As another poster mentioned, the initial cost kind of took my breath away but the replacement inserts are about cheaper than I could make them for.
Dave
Rick L
Re: That type could easily be made from
Rick L
>woodscraps. Think about it. Actually saww an article in one of the hobby woodmags doing such a thing. Actually bought the real thing for our shop even though I could have easily made one from aluminum plate. In my opinion one should have at laeast 20 extra throat plates on hand for different dado blades, angles, etc
Picked up a LV Catalog today
Robert Hutchins
>and right there near the front was a device like (I think) you're describing, Rod. It's in the January 2007 supplement on page 3, upper right. This one has a notch so blade splitter/guard can remain in place. The inserts are phnolic resin. Price $80 for most saws (didn't see a Grizzly) and the repl inserts are $18.50 for a package of 2.
No connection with Lee Valley - not even a Canadian - just a happy customer.
BobH
