OT - Plumbing vent question
John in MD
>Thanks in advance for any wisdom...
I have a vent pipe in my basement, labelled by the builder as "future vent", in the ceiling in the roughed-in area of the basement intended for a future bathroom (we have no intention of making a bath dowm there, but there's drain pipes in the floor for sink and toilet, leading to the sump pit).
Today, we noticed a drip from this pipe. I opened the plug at the end of the pipe (in the roughed in bath space) and got about 6 gallons of water....
I figure it's rainwater collecting at the lowest point of the vent system, but I don't know where this should drain to. If we do install a sink, where will this vent get connected to?? Should it connect to the sump, somehow??
Thanks!
-John-
Re: OT - Plumbing vent question
John Parker
>It sounds like the vent pipe goes out the roof of your house. You can get up on the roof and verify this. What I would do is cap off the vent pipe on the roof to stop water from filling it. If you ever use the vent in the future ,just remove the cap.
Al Stokka - Cambridge, Iowa
>John,
I can think of no normal situation in which a vent pipe would hold water. There must be an obstruction downstream (toward the sewer or septic tank) from the cap you removed. Even if the future bathroom toilet/sink isn't in use, the drain pipes would still be connected to the drain pipe and should carry any water in the vent pipe to the sewer/septic tank.
I'd investigate were it mine.
Al
I think he means its capped at the bottom...
John in New Mexico
>Since its not in use (yet) there was no reason to connect it to the drain, as the builder would have no idea where future fixtures would actually go- but that's just how I read it, could well be wrong.
I'd go up and cap it, they also make oversize caps with set screws that allow the vent to operate without letting precipitation in. One of those might be a good idea so that some future remodeler doesn't have to figure out the hard way why he's having venting problems. Or if more effort is not a problem, just connect the vent to the drain.
John
Thanks for the replies!
John in MD
>Thanks for the replies - yes, John the pipe is capped at the bottom, not connected to the drain, yet (and maybe never)...
I'm not certain, but I think there's only one vent in my roof, so I'm hesitant to cap off the vent on the roof, for fear it's functioning for all the other drains in the house. I'll look into some kind of vented cap and see if that solves the problem.
THanks to all who replied!
-JOhn-
Re: I think he means its capped at the bottom...
>I guess I'm wrong since he says it's capped at the bottom. Since the drain for the tiolet is in the floor, that fixes the location of the toilet. Why wouldn't the builder (plumber) hook the vent to that drain? Sure, it would serve no purpose, but how to easily hook it up when the toilet is installed? Bust up the concrete floor I guess?
Al
Mysterious are the ways of builders!
John in New Mexico
Re: Thanks for the replies!
>If you have only one vent through your roof, this one must be connected into it, otherwise it could not vent.
This raises a question about the water you found. If it was rainwater, this vent must be catching some of it if not all of it. If you leave it uncapped, you could be letting sewer gasses into your house. It is also possible that some of the water was either septic or grey water from some other part of the system. It also possible that part of it is condensation that accumulated in the pipe.
Might be best to cap the bottom with a water proof cap that does not leak or have a plumber hook it into a drain so that it can drain and not leak water or gases into the house.
Re: Swamp gas
John in MD
>Thanks, Barry - I guess I didn't make it clear - the bottom of the pipe labelled "future vent" has a plug, which is what i unscrewed to drain the water. What I was referring to capping was the pipe exiting the roof, which I believe is the common vent for all the drains in the house, including the problematic basement vent....
The water I drained was clear and smelled clean - definitely not wastewater from sinks, tubs, washer, etc; so I believe it's rainwater, and for some reason this basement drain is either a straight shot to the roof, or is somehow the path of least resistance for rainwater entering the roof pipe. We had some real gully washers here the past couple of days, so some of it was recent....
I'll try a ventilated cap on the roof pipe, and try to remember to pull the basement plug every few years to drain whatever may find its way inside....
Thanks to all who've replied.
-JOhn-
Re: Mysterious are the ways of builders!
Lee Brubaker
>Oh I can tell you a lot about the mysterious ways of plumbing contractors....especially if you live outside of an area with municipal sewer systems aka acreage. Also NEVER build during a boom.
First off, most residential plumbing is roughed in by an apprentice & often results in strange piping. We built a bungalow with a walk out basement...plumber dropped a 4" soil pipe down directly in front of a large picture window. Thirdly, he did not hook the iron filter & water softner discharge piping to anything. Had one of those kicked in...300 imperial gallons dumped into the basement.I could go on about that plumbing contractor but it would get tedious or be just plain carping.Except for one thing....the jerk installed the bath tubs sloping to the drain end...never mind that tubs have built in drain slope.When you don't discover this until after the drywallers have been it makes for interesting tiling of the tub surround.
Lee
Re: Swamp gas
>I had a point in there somewhere. Maybe a couple of points.
The plumbing vents should be plumbed to drain into the plumbing system so that this won't happen. It's obvious that some rain will go down the pipe. Also, less obvious, some condensation will form inside the vent and drool back down. (DAMHIKT) So the vents would drain. Yours is "temporarily" interrupted from draining because it is not connected at the bottom, but apparently still accumulating water from the top. You want to be sure this water and potential swamp gas does not leak into the house. You either need to properly connect this to the drainage system or provide an excellent plug. Wouldn't want some cheap light duty plug to pop out someday and dump gallons of water. You put in the plug, but Murphy pulls it out.
OTOH, It was good of the builder to provide the vent. The rain cap might be a good idea.
Radon Gas Vent
Matt Robinette, Mt Juliet Tn
>I have seen builders install vents in basements for possible radon venting in the future.
Matt
