Custom DC Pipe Hangers
Keith Weber
>I've had my Dust Gorilla for WAY too long now, but I've been neglecting putting up the 6" piping because I've had other projects consuming my time.
Yesterday, I decided to tackle the problem of hanging the pipe on the walls. Sure, I could have just used tie wraps or metal strapping, but that would have been too easy. Instead, I decided to design and build my own hangers out of steel.
I made them out of 1/4" x 1" flat steel. I made the rings on a hand-operated ring roller. I used my Miller Dynasty TIG welder for the welds. The design allows for a 7" hose clamp to fit around the ring and 6" S&D pipe that I'll be using. I made the rings 1/4" big in diameter to accommodate some adhesive-backed weather stripping on the inside of the ring to dampen any vibration.
The reason that the vertical hangers have more ring on the bottom is two-fold. It allows me to put up the horizontal pipe during assembly without needing to put the hose-clamps on right away. It also allows me to drive the screw in the top.
The symmetrical hangers are to be horizontal to steady the vertical drops. I think that I'll need about 4 more hangers, but I ran out of steel, so they'll have to wait for my next set of days off.
Although, I'm kind of liking the shiney steel look right now, I think that I'm going to get them powder-coated white to match the trim in my shop.
While I've got everyone's attention...how to you attach a PVC 6"-4" Stepdown to a 4" Flex hose?
Keith
Re: Custom DC Pipe Hangers
Pic 2
Keith Weber
Pic 3
Keith Weber
You created hanger envy!
Eddie Pacheco, San Jose, Ca.
>Nice design and nice uniform looking welds on those duct hangers.
You GOTTA post the finnished system !
s.mackay@worldnet.att.net
>And what spacing are you envisioning for these? They'd hold up a boat!
Worst looking lawn
Mike from Tn.
>So much for the landscaper having the worst looking lawn on the block. If you've got the time, material, and talent,,,, Why not? Good job
I don't know about the step-down...
Craig Daymon
>...straight to 4" flex hose, but Woodcraft has several fittings for on sale right now to make the connection from 4" PVC (Schedule 20?) to flex hose and, I think from 4" steel to 4" PVC. Check their dust collection section. I've got a Gorilla that needs set-up as well, but no hangers as nice as those. I was planning on using zip ties. (I just order a bunch of the connectors, that's how I know. I ordered parts #145986 and #145985.)
-Craig
Re: I don't know about the step-down...
Larry in NW Ohio
>Keith Some outstanding hangers, I wish I could have done something like that.As for the 6 to 4 to flex, just get a 6-4 stepdown and put a 4" by about 4 to 5 inches long S&D in the stepdown and slide your flex on that. That`s how I did mine. Larry in Ohio
Keith Weber
>Thanks Larry! I'll have to buy some 4" S&D pipe and try that. It would save me a trip to Woodcraft if it works. Wherever I have a tool with a 4" port, I just plan on splitting the 6" into two 4" pipes with the blast gate on the 6" pipe. I'll have two tools "getting sucked" at the same time, even if I'm not using the second. That should keep the flow speed relatively constant in all of the pipes and keep the 6" pipe from being choked by a single 4" port.
Keith
