200+ woodworking book reviews
Planer Feed Problems - Redux
Stephen Kirk in Quakertown, PA
>Since there were some recent posts about feed problems, and I was having some with my Delta lunchbox, I thought I should post about my very recent cleaning experiences. I was having the same problem described - a board would stop feeding and then you need a lot of pressure to push it forward, and you get divets in the wood. Yesterday, I did a thorough cleaning of the rollers with just some warm soapy water. On the Delta you have to cycle the motor to turn the rollers (make sure you unplug it each time before reaching your hand in there). Then I waxed the infeed/outfeed and main table of the planer with Slipit (a sliding compound). You put it on and then buff it off just like paste wax.
Then I spent the evening planing down some nasty old 2x4 material (for a workbench). I planed for about 2 hours and saw no more feed issues - unless I hit a low spot that the infeed rollers couldn't grab!
I've found that I'll need to clean the Delta about 2-3 times per year, depending on how much planing I do (and I generally use a few times every few months). I also change the knives when I start seeing a lot of tear-out (in either grain direction). I may reverse/swap the knives every year or so (again, depending on use and how it cuts).
Re: Planer Feed Problems - Redux
GolfSteve in Calgary
>When planing continuously with my Dewalt 735 I find I have to clean the rollers about once an hour.
I rub down the rubber rollers with isopropyl alcohol on a paper tower, and squirt some camelia oil on the table.
>Wow, I guess the dust builds up pretty fast on the rollers. I did notices that even a light layers of dust can keep the rollers from grabbing.
Lee Brubaker
>Isn't that strange...I have the Delta 2 speed 13" planer & it is now about a year old. Have done a fair amount of planing both hardwoods, as well as softwoods plus reclaimed construction lumber & have yet to have a feed problem. Have never cleaned the rollers. Gonna start crossing my fingers from now on when planing.
Lee
