>Since so many of you were kind enough to share your thoughts on big "old arn" vs new, thought I'd share a pic of my new jointer.
It's a 16" Crescent, mfg date is approx 1916. In great shape, nice and tight. Can't wait for it to warm up a bit so I can get into the shop and start making sawdust, or planer chips in this case!
Thanks to all who helped me sort through this purchase.
>Congratulations! I'm glad you went this route--you'll be happy and will not be limited in jointing wide boards! Looks like it's in great shape. Lucky you.
>I'm happier than a pig in mud with this purchase--and all I can do at the moment is look at it!
It's in really great shape and with the exception of the blade guard, which was mfg'd by Surty and not Crescent, it's completely original, paint, decals, and all. Came out of Julius Petersen Boatyard in Nyack, NY. According to the guy I got it from, it was being used until a short while ago. Seems like Petersen's sold off all their old equipment in favor of new, at least that's what I was told.
>are better than a parallogram jointer set up in my opinion. Easier top adjust and if you need to remove the table for grinding it's a snap to remove and put back on. I've worked on a lot of jointers and the Crescent is one of my favorites in simplicity. I'm assuming it's babbitt. Nothing wrong with babbitt. Is it the round head?? Crescent seemed to have a round head early on.
It's an amazingly simply machine. Just a couple of bolts per side, six technically, and the whole thing comes apart. It is babbit and has a 4 blade Crescent saftey (round) head. I set up a dial indicator to check the bearings when I bought it and was getting approximately 0.002".
I almost bought a 20" Oliver instead from the same guy, Jeff. It is somewhat older, has a two blade clamshell head and needed to be cleaned up a bit. I think Jeff took pity on me and felt better putting me into a safer and probably more versatile machine for a hobby woodworker whose specialty is sawdust and firewood!
>You don't want the clamshell head. Best way to set the knives on the crescent is to pull the tables apart a bit and set the knives to the head. www.woodtechtooloing.com has a nice setting gauge. I know the Crescent well. The base is better than the Oliver. You can move the Crescent around without having to reset the tables. The Oliver is much more complicated to line up everything.
