Ridgid bummer... (long)
Denis Ch�nard, Orl�ans, Ont.
>For space reasons I sold my contractors saw last year and purchased the Ridgid jobsite saw. I knew I was making a compromise by downsizing, but the space savings made it worth it in my book. My biggest griefs are table size and cut quality, but power is as good as a contractors saw.
So far I've used the saw only for cutting sheet goods and a bit of ripping, and it has worked fine. Last night I finally installed and fitted the JessEm MiterExcel miter gauge (wonderful gauge, BTW) to the saw, and that's when I made a most unwelcome discovery...
Fitting the gauge took a couple minutes and was painless. But when sliding the gauge to the back of the saw, then pulling back, the washer that's fitted to the underside of the guide bar would catch and I had to rock the gauge so the washer would slip back in the groove. Great, I thought, the gauge bar isn't flat... Mumbling to myself, I took my straightedge out to check how much out of flat the bar is, only to find out that the bar is dead flat.
That could mean only one thing, the table is crowned... Put the straightedge to it, and sure enough, it is crowned roughly 1/16" front to back on the left of the blade, a bit less on the right. And the miter slot follows the same curvature...
Now I never bother to check the table for flatness when I purchased the saw, so I don't know if the table was flat then warped, or if it was crowned from the start. I haven't registered the saw, and I'm not even sure I still have the sales receipt (I'm terrible at paperwork, as you can see).
So I feel like I'm up the proverbial creek without a paddle :-(
I'll check tonight to see if I still have the sales receipt, meanwhile I would appreciate any suggestions as to how to deal with this problem with Ridgid. The saw is still useable and will cut precise miters despite the crown, but bevel or compound mitre cuts will be affected.
TIA,
DC
Feeling like an idiot this morning
Re: Ridgid bummer... (long)
Larry in NW Ohio
>Denis The only way is to call them. I don`t reall think the table would warp in your shop. Go to the store and talk to them and then call Ridgid. Best of luck. Larry in NW Ohio
Lee Ohmart
>Where did you buy the saw? Many retailers have a limited warranty on the items they sell and most are very reluctant to let a customer be unhappy. You can also check into your state laws. Here in Maine, all durable goods have a state mandated 4-year warranty regardless of any other warranties.
Eddie Pacheco, San Jose, Ca.
>If you can't return it or if it's not covered by the warranty, try to shim the table at the outside left points where it is fastened to the frame. Of course this most likely will entail realigning the miter slot to the blade if you have to loosen all of the screws and the table gets bumped a bit.
Let us know how this plays out.
Al Stokka - Cambridge, Iowa
>Denis,
Did you use a credit card for the purchase of the saw? If so, do you have the staement on which the saw appeared? Might serve as proof of the date of purchase. If not, perhaps the credit card company can supply a receipt.
Also, some credit cards offer a warranty over and above that of the manufacturer's.
Hope it works out for you,
Al
Howard Acheson
>In the US, that saw is covered under the Ridgid "Lifetime Service Agreement" if you regeristed it at the time of purchase. The Warranty is one year only I believe.
Ridgid is HD's House Brand
Howard In Toronto
>HD should be able to tell from the serial number or any other production-run coding on the saw's body when it was PRODUCED.
This info doesn't tell when the saw was PURCHASED.
HD should have pretty accurate stats on how often they turn over one of those saws. They should be able to calculate production, shipping, cartage, stocking and finally, sale time frames for you.
I'd like to think HD/Ridgid will go an extra mile or two for the sake of creating long-term loyalty.....
HTH
Howard
>Good Afternoon Denis,
We, who have two similar saws in the family, have not confronted that specific problem. It is a bummer. I suggest you go back to the store you purchased it from and ask them to exchange it. I'm sure they will do so with or without your original receipt. Let us know. I am contacting my #1 and #3 sons and have them check for a crowned table on their saws.
George
>Thanks Colonel, I can't do the same with my own #1 and #3 sons, as they're not old enough to be around tablesaws yet (7 years, and 14 months old, respectively) :-)
DC
Dan Clermont
>Hi Denis
If you bought the saw with a credit card HD may have a record of the purchase.
Sorry to hear about the crowned table top. I have no suggestions on how to remedy that problem
Dan Clermont
Mark Nowicki
>Hi Dennis:
Sell it. In all fairness to Ridgid, jobsite saws are manufactured to different standards and intended use that contractor or cabinet saws.
Regards
Mark Nowicki
true
Joe Piotrowski - Chicago Burb's
>be prepared you may get the an answer that it is with tolerances.
considering the outraged cost of those saw, they should be as good as the CS saws.
BTW, for my education, what is so space saving about it? do you not put it on a stand?
Re: true
J. Robison
>I'll second that. You might find a framing contractor who would find no problems using that saw.
As my commercial electrician brother-in-law told me once.....there's no 1/8" measurements on the site, only fat quarter inches.
Understood Denis, But
>is your saw old enough to wear----a crown?
George
Re: true
Mike Boren
>From my experience Home Depot is very liberal with their return policy. You should be able to take it back and easily exchange it for another saw.
Without the reciept you won't get a refund but they will do an exchange or offer store credit.
I worked for HD a few years ago and was amazed at some of the things that were returned.
Re: Understood Denis, But
>That was baaad, Colonel! :-)
DC
space saving
>The saw sits on a folding stand on wheels, when folded it takes about two square feet of floor space. Compare that with my CS that took 24. Makes a major difference in my small shop...
DC
Re: space saving
>if you find that job site saws are to inaccurate there are other alternatives.
I have not purchased nay of these but I look into them a lot. I am not fond of my CS. I could upgrade but when really thinking about it, I don't do production work. and there is ot an operation that can;t be done else where.
a TS can do a lot of things good enough. that makes it a useful tool but there are usually ways to get better results. they make take longer. givien my experiences I would rather have a kick butt workbench and good Bandsaw than a TS.
if someone knows of an operation that can't be done on a TS I would like to know what it is.
the festool saw system seams nice and may solve your issues if Job site saws are a bust.
let us or at least me know the outcome. I just never know what I will impulse buy :)
Re: Ridgid Forum
Norman (Ottawa, Ont.)
>Denis,
There is a Ridgid Forum you can ask about this, or check.
I found this out a couple of years back in researching a tool.
They have different sub-Forums including Power Tools at the link below.
http://www.ridgidforum.com/forum/index.php
Norman
Don't understand the geometry here...
>"... two square feet of floor space. Compare that with my CS that took 24....
When you say two square feet I'm assuming you mean 2 foot by 2 foot, or 24" x 24", which is actually 4 square feet, right? You couldn't mean 2 square feet. That would be be about 16" x 16" inches.... is that right? That's tiny, even for a job saw isn't it? Or maybe that's right.
And 24 for your old contractor's saw? You'd need to have a tablesaw with a 12 foot extension table, no?
I've had a long day... perhaps I'm not thinking right. How are you comparing a 2 squarefoot footprint saw with a 24 sq.ft footprint saw?
Happy Woodworking!
Re: Don't understand the geometry here...
>No, two square feet means two square feet, i.e. two feet by one. The saw flips up on its stand and stays vertical.
As for the 24 square feet for my old CS, with the fence (with a router insert between the rails) and a folding extension table that had to extend beyond the outboard motor for the second part of the extension to fold down, that made the saw six feet wide by four feet deep app.
Of course the jobsite saw takes more space when unfolded and in use, but I can fold it out of the way when I need space, something I couldn't do with the old CS.
DC
Thanks
>I undertand now, I didnt' realize you were laying the jobsite saw on it's side. Makes sense now.
I'm usre you already thought of this, but at shows I often see people using stripped down contractors saws. They remove the wings nd have as small as a saw as you can get. You get the qauilty of the saw (cast iron,etc) but in barely portable size.
I've often though that if I removed the left extension on my Unisaw, and made folding right extension, and somehow make it soe the fence rail could fold upwards, then I could have a Unisaw with a 2x2 foot footprint.
I'm not sure how the Home Depots (or Reno Depots) in Canada are, but here they let you return just about anything in almost any shape with a good enough reason.
Happy Woodworking!
Happy Woodworking!
