Powermatic 63 seizing up
Mitch from TN
>I'm writing again about my Powermatic 63 contractor's saw. I turned it on earlier and the motor just completely seized up. The blade wasn't turning at all. I turned it off as quickly as I could. But even when I flipped the power switch, it was still making a humming sound. I then unplugged the saw. After a little while, I plugged it in and turned it on again, with the same result. What could I have done to cause this to happen???
A week or so ago, I was working with the trunions, trying to align the saw blade. I got it fairly well aligned and tightened everything up again. When I loosened the bolts to move the trunions, I had to jostle it to get it to move. Is this what caused my problem? Is there any hope for this table saw?
Thanks in advance,
Mitch
Re: Powermatic 63 seizing up
Dan Donaldson
>With it unplugged, can you rotate the blade/motor by hand? If not, then something is binding or rubbing such that it is stopping the saw. If you can turn it easily, then either something has gone wrong with the switch, or the motor. You mentioned that it kept humming even when you turned it off. This could indicate that there is something wrong with the switch.
>Mitch There's a good probability it's the switch. The switch on this saw gets dirty and doesn't work right. Pull it out and clean it. It's not hard to take the switch completely apart and clean the inside. If you don't feel comfortable doing that, try getting another switch.
First I would try to rotate everything by hand t make sure nothing is binding up. Since it's still humming when you turn it off I think it points to the switch.
I won't be as busy for the next several weeks as I am in the late fall so if you keep having problems send me an e-mail and I'll see if I can get to Nashville and look over your saw.
Randy Johnson Connersville, IN
>Is the saw 110 or 220? If it's 110 and spins freely by hand I would bet on a blown capacitor over a switch. A bad switch could stop one side of 220 to get through and give you the hum you hear but at the same time a hum indicates SOME electricity is getting to the motor. A blown capacitor would give the same symptoms you are having. Capcitors are easy to replace, usually available at large supply houses, and normally show easily visible sign of having failed. If it isn't obvious put an analog ohm meter on the leads. With a good capacititor the needle will swing all the way to the right and then drop back. With a bad one it won't do anything.
David
>I don't recall the configuration of this saw. Is it similar to a contractor saw ? i had a similar problem with my Delta contractor saw recently. the motor hangs off the back and saw dust got into the motor. I blew the saw dust out and the motor has worked fine since that clean-up.
Mitch from TN (formerly from NYC)
>Thanks, everyone, for your help. The saw is a contractor's saw and is 110. I'll try out your suggestions of trying to turn the blade and if it turns ok, try to clean up the switch. In case it is the switch, does anyone have a source for new switches? I've been thinking about installing a larger, easier-to-use switch anyway. This may be a good opportunity.
Thanks again,
Mitch
