Motor Rotation CW OPE, Direction?
John Weber - GO BUCKS!
>I have a c-face motor with a CW OPE rotation. Does that mean it's clockwise looking at the shaft or looking from the rear. I assume it's looking at the shaft end, but wanted to double check.
Thanks - John
Re: Motor Rotation CW OPE, Direction?
Jim Swank
>I don't recognize the "OPE" designation. Could it have been "ODE"? If so, it is Opposite Drive End, the NEMA standard for rotation.
For a normal motor with a single ended shat, the shaft is the Drive End. To make it easier to remember rotation, picture the shaft as the head of a horse. If you straddle the body - just like riding the horse - facing the shaft (the horses head), you're viewing the motor correctly to understand rotation.
There's always a few that seem to prefer facing the other end of the horse....
You guys are making my head hurt.......
>I have disgraphia or dislexia or left/right orientation "issues" or something. A motor is a horse with a rotating head? Horses heads rotate? If I gave my kid a horsey back ride, would my head rotate? My cousin had a horse and best I recall its head did not rotate, but it wasn't much of a horse.
I would want to look at the motor from the end of the shaft and orient my watch so its shaft was paralel and use that to determine "clockwise", but that's too easy.
ODE? Who cares what the ODE is doing? I want to know what the Drive End is doing.
There are so many things I don't know. Took me years to realize the wind direction is stated in the direction it came FROM. I guess its more important to know where it came from than where it going.
I would have to hook up the motor and watch it.
Re: You guys are making my head hurt.......
Larry Clinton in Frankfort, Indiana
>Motor direction is normally stated as the rotation looking directly at the end of the drive shaft. I am not sure what the OPE designation relates too - Often there is an ODP which means Open Drip Proof, this has nothing to do with rotation. A CW (clockwise) motor should run the same as your watch hands when viewing the end of the drive shaft.
Larry in NW Ohio
>OK Larry Clinton Just for clarification a motor can be open and still drip proof? Just sounds kind of srtange to me. Larry in NWOhio
Al Stokka - Cambridge, Iowa
>As I recall, a drip-proof motor can be open. The motor shaft is tilted 15� up from from horizontal and if nothing enters the motor guts and causes a problem, it can be classified as drip proof.
Surely, if I'm wrong, someone will correct this? (Stop calling me Shirley.) Sorry, I watched Airplane yesterday.
Al
Re: Shirley: OPE and drip-proof defined
>Stolen (without permission, of course) from:
http://www.reliance.com/prodserv/motgen/b9652new/b9652.htm
DRIP-PROOF MOTOR
An open motor in which the ventilating openings are so constructed that drops of liquid or solid particles falling on it, at any angle not greater than 15 degrees from the vertical, cannot enter either directly or by striking and running along a horizontal or inwardly inclined surface.
FRONT END OF A MOTOR
The front end of a normal motor is the end opposite the coupling or driving pulley (NEMA). This is sometimes called the opposite pulley end (O.P.E.) or commutator end (C.E.)
Text is bolded by yours truly.
Al
Jim Swank
>Sounds like OPE and ODE are the same thing, even if I hadn't heard of the one. Thing is, we as normal users would expect one thing, and the standards call for the opposite.
The horse analogy is just a way of remembering which way is which if you need a mental picture to keep it straight. I stared at the wrong end of the horse a few times myself before I figured it out.
So, looking at the back end of the motor
Don Henthorn
>should give you the rotation?
