Both varnish and shellac are classic, beautiful finishes, but they behave very differently and suit different projects. Here’s a practical breakdown to help you choose the right one for your work.
Quick comparison table
| Feature | Shellac | Varnish (Oil-based or Water-based Polyurethane) |
| Origin | Natural (lac bug resin dissolved in alcohol) | Synthetic or oil/resin blends |
| Sheen | High gloss to satin (easy to adjust) | Gloss, semi-gloss, satin, matte |
| Durability | Moderate – good for interiors | Excellent – best for tables, floors, outdoors |
| Water Resistance | Poor (turns white with moisture) | Very good to excellent |
| Alcohol Resistance | Poor (dissolves in alcohol) | Good |
| Drying Time | Very fast (minutes between coats) | 2–6 hours between coats, 24 hrs to cure |
| Ease of Repair | Excellent – just dissolve and reapply | Good (but harder than shellac) |
| Food Safety | Pure shellac (dewaxed) is food-safe | Most varnishes are not food-safe |
| Odor | Mild (alcohol smell) | Stronger (especially oil-based) |
| Best For | Furniture, musical instruments, French polish, sealing | Tabletops, kitchen cabinets, floors, exterior wood |
When to choose shellac
- Seal coat / primer: Shellac sticks to almost anything and seals in resins, oils, and odors. Many woodworkers use a coat of dewaxed shellac under varnish or lacquer.
- Antique restoration & traditional work: It gives that warm, glowing look old furniture had.
- French polish: The classic high-gloss technique on fine furniture and guitars.
- Fast projects: You can build a full finish in one afternoon because it dries so quickly.
- Toys or food-contact items (use dewaxed, alcohol-based shellac flakes you mix yourself).
Tip for beginners: Start with pre-mixed Zinsser SealCoat (dewaxed shellac). It’s reliable and easy.
When to choose varnish
- High-wear surfaces: Dining tables, bar tops, kitchen cabinets, stair rails.
- Outdoor projects: Spar varnish (marine varnish) is flexible and UV-resistant.
- Floors and doors: Polyurethane varnish is the standard.
- You want “set it and forget it” durability.
Modern choice: Water-based polyurethane is popular because it has low odor, dries fast, and doesn’t yellow over time. Oil-based varnish gives a warmer amber tone but takes longer to cure.
Common woodworking combinations
Many experienced woodworkers use both:
- Thin coat of dewaxed shellac as a sealer.
- 2–4 coats of varnish or polyurethane on top for protection.
This gives you the best of both worlds: shellac’s excellent adhesion and warm color + varnish’s toughness.
Quick decision guide
Use Shellac if:
- The piece is mostly decorative
- You want a traditional look
- You need to finish quickly
- You’re French polishing or restoring antiques
Use Varnish if:
- The piece will see water, drinks, or heavy use
- It’s a tabletop, floor, or exterior project
- You want maximum durability with minimal maintenance
Varnish vs. polyurethane
Yes, they’re related but not exactly the same. In everyday woodworking talk, people often use the terms interchangeably, but there are real differences in chemistry, performance, and how they feel on wood. Here’s a clear, practical breakdown.
| Feature | Traditional Varnish | Polyurethane (“Poly”) |
| Base Chemistry | Oil + resin (alkyd, phenolic, or urethane) | Polyurethane resin (can be oil-modified or water-based) |
| Typical Look | Warm amber tone, softer sheen | Clear or slightly amber; can be very glossy |
| Flexibility | Excellent (especially spar varnish) | Good, but can be more brittle when fully cured |
| Durability | Very good for exterior & marine use | Excellent for high-wear interior surfaces |
| Water & Chemical Resistance | Good (spar varnish is best) | Outstanding (especially water-based poly) |
| Ease of Application | Brushes well, levels nicely | Can be trickier (bubbles, lap marks) |
| Recoat Time | 4–24 hours depending on type | 2–6 hours (water-based faster) |
| Common Uses | Outdoor furniture, doors, marine projects | Kitchen tables, floors, cabinets, trim |
| Yellowing Over Time | Moderate to heavy (oil-based) | Water-based: minimal; Oil-modified: noticeable |
Simple explanation for woodworkers
- Varnish is the broader, older category. It’s basically a blend of drying oils (like linseed or tung) and natural or synthetic resins. Traditional “spar varnish” is still the go-to for boats, outdoor gates, and anything that needs to flex with temperature changes.
- Polyurethane is a specific type of varnish that has been chemically modified with polyurethane resin. That’s why you’ll see cans labeled “Polyurethane Varnish” or just “Poly.” The polyurethane part gives it superior toughness, abrasion resistance, and faster dry times.
Think of it like this:
All polyurethane is a varnish, but not all varnish is polyurethane.
Two main types of poly you’ll see
- Oil-based Polyurethane
- Classic choice for a warm, amber glow.
- Very durable for tabletops and floors.
- Strong odor and longer cure time (can take days to weeks to fully harden).
- Great if you want that traditional “varnished wood” look.
- Water-based Polyurethane
- Crystal clear – doesn’t yellow the wood much.
- Low odor, faster drying, easier cleanup (soap & water).
- Slightly less warmth than oil-based, but modern formulas are excellent.
- Ideal for light-colored woods or when you want the grain to stay bright.
Practical advice for your shop
- For high-wear surfaces like dining tables or butcher blocks: Use a good oil-based or water-based polyurethane. It will hold up to plates, glasses, and cleaning better than straight varnish.
- For outdoor projects or anything that moves with the weather: Traditional spar varnish (a true marine varnish) is usually the better choice because it stays more flexible.
- Many woodworkers still start with a coat of dewaxed shellac (as we talked about earlier) under either varnish or poly. It improves adhesion and gives a nice base color.
Beginner tip: If you’re new to finishing, start with a water-based polyurethane in satin. It’s forgiving, dries fast, and you can sand between coats easily with 220-grit. Just stir gently — don’t shake the can or you’ll get bubbles.
Little-known woodworking fact: Shellac was the original “high-tech” finish in the 1800s — it was used on everything from violins to bowling pins. The word “varnish” actually comes from the Italian vernice, which originally referred to a resin from the Mediterranean larch tree. Both finishes have been protecting beautiful wood for centuries!
