Woodworking offers a huge menu of finishes, each with its own personality, strengths, and ideal uses. Here’s a practical guide to the most common alternatives, plus when you’d reach for them instead of shellac or varnish/polyurethane.
Quick comparison table
| Finish | Ease of use | Durability | Water resistance | Appearance | Best for | Drying time |
| Lacquer | Medium | Good | Moderate | Crystal clear, high gloss | Furniture, cabinets, production work | Very fast (spray) |
| Oil (tung, Danish, linseed) | Very easy | Moderate | Low | Warm, natural glow | Furniture, cutting boards, salad bowls | 1–3 days between coats |
| Wax (beeswax, carnauba) | Very easy | Low | Low | Soft satin sheen | antiques, decorative pieces, over other finishes | Immediate |
| Penetrating oil (e.g. Watco Danish oil) | Easy | Moderate | Moderate | Enhances grain, matte | Furniture, trim, interior projects | 4–6 hrs |
| Conversion varnish / lacquer | Advanced | Excellent | High | Durable, clear or tinted | Commercial cabinets, bar tops | Fast (needs catalyst) |
| Water-based lacquer / acrylic | Easy | Good | Good | Clear, low odor | Light woods, kids’ furniture | Fast |
| Milk paint | Easy | Moderate | Low (needs topcoat) | Matte, colonial look | Primitive furniture, painted pieces | 30 min–1 hr |
| Two-part epoxy | Medium | Very high | Excellent | Thick, glass-like | River tables, bar tops, waterproofing | 24 hrs full cure |
Quick decision guide for woodworkers
- Want maximum clarity and speed? → Spray lacquer (nitrocellulose or water-based). It’s the finish of choice for most factory furniture and gives that “wet look” without much color change.
- Love the natural feel of wood? → Pure oils like tung oil or boiled linseed oil. They soak in rather than sit on top. (Note: Pure linseed oil can take weeks to cure and may darken over time.)
- Need something food-safe and simple? → Food-grade mineral oil + beeswax blend for cutting boards, or pure tung oil for bowls.
- Looking for easy repair and a soft sheen? → Paste wax over any hardened finish. It’s not a stand-alone finish but great for maintenance.
- High-wear commercial look? → Conversion varnish (acid-catalyzed). It’s tougher than regular polyurethane but requires good ventilation and a spray gun.
- Rustic or painted finish? → Milk paint gives an authentic early-American look and can be distressed easily. Top it with wax or shellac for protection.
Common combinations woodworkers love
Many pros layer finishes for the best results:
- Danish oil or tung oil as a first coat to pop the grain, followed by 2–3 coats of water-based polyurethane for protection.
- Shellac as a sealer, then lacquer on top (they play very nicely together).
- Oil finish + paste wax for a low-maintenance, hand-rubbed look on furniture.
Beginner tip: If you’re just starting out, try General Finishes Arm-R-Seal (an oil-based topcoat) or a simple tung-oil blend. Both are brushed on, build quickly, and forgive small mistakes. Sand lightly with 320-grit between coats and you’ll get a professional result.
Little-known woodworking fact: The ancient Egyptians used a mixture of beeswax, resin, and oil to finish their furniture over 4,000 years ago — some of those pieces still look great today! Modern finishes may be tougher, but the desire to protect and beautify wood hasn’t changed a bit.
