Puzzler -- Window replacement
Alex Y
The builder of my house was an eccentric soul. In a storage room, he put a single square window on the north wall, centered horizontally on the wall, and with the bottom 36" above the floor and the top 72" above the floor. This window did not provide enough light during the day, so I asked a remodeler if he could improve the situation. He replaced that window with another square window, also centered horizontally, 36" high and placed 36" from the floor, with the same type of glass.
This immediately improved the amount of light I was getting during the day. How did he make this improvement?
Re: Puzzler -- Window replacement
Sam Force
I'll bite, he put the window on the south. But could be different depending on home location. Or maybe remove an obtrusive tree 8) :\
No
Alex Y
But shame on me for not specifying that it went in the same wall.
Cutting down a shade tree would be a good practical solution, but not a very interesting puzzle.😄
Hint
Alex Y
The new window lets in twice as much light as the original.
Charles Murray
The window is twice as wide.
No
Alex Y
Both the original and the replacement were square.
Henry Higginbotham
I've looked at this several times now without an epiphany. Maybe one-way windows installed in opposite directions?
I think some dimensional sleight of hand is more likely, and that a D'oh! moment awaits.
Larry Barrett
I think the remodeled replaced the window and then opened the curtains.
Hint 2
Alex Y
"The builder of my house was an eccentric soul."
That was in the original statement of the problem, but I point it out again as an area for investigation. And "eccentric" here means "unconventional and slightly strange"--nothing about a cam or circle mounted on an axis that does not go through the center of the circle.
Re: Hint 2
Sam Force
My only thought would be to "skew" the window R or L which would give slightly more E to W length
No, but
Alex Y
I like the way you are thinking.
Last (Big) hint
Alex Y
The original window was (approximately) 25.5" square.
Re: Last (Big) hint
Henry Higginbotham
And about as out-of-plumb as he could get it? Cute. And ... D'oh!
Correct 😄
