8457898
Saturday Puzzler -- Triangle and Square
Alex Y
Friday's was apparently too easy -- Sam [almost] knocked it out nearly as soon as I posted it. So let's try another:
Draw a square with horizontal and vertical sides. Draw a diagonal from the lower left corner to the upper right corner. Draw another line from the lower right corner to the midpoint of the top side.
Consider the triangle formed by these two lines and the bottom side of the square. What portion of the area of the square is in that triangle?
Re: Saturday Puzzler -- Triangle and Square
Larry Barrett
1 - 1/2 - 1/6
Correct!
Alex Y
I obviously have to find some tougher puzzles!
Just curious if 1 - 1/2 - 1/6 was just your way of giving the answer of if it is how you solved it. If the latter, how did you come up with 1/6?
The solution I saw noted that the triangles created on the bottom and top sides were similar. Taking the horizontal sides of the triangles as the bases, we see a 2:1 ratio, that also applies to the altitude, so the altitude of the larger of the triangles is 2/3 times the base.
Area of triangle = 1/2 * base * altitude
= 1/2 * base * 2/3 * base
= 1/3 * base^2
Re: Correct!
Henry Higginbotham
That's more elegant than how I saw it, which is that one line has a slope of 1 and the other a slope of -2, so their intersection must give the triangle a height of 2/3. But by then Larry had already posted the answer.
Re: Correct!
Larry Barrett
My way probably more complicated than your's or Henry's solutions.
Label the corners of the square, starting in NW corner and moving CW: A, B, C, D Label each side s and label the midpoint of side AB F.
Draw a diagonal from D to B.
Draw another line from C to F and label the intersection of this line with line DB E.
We want to know the area of triangle DEC with respect to the area of the square, which is s^2.
Area of DEC = s^2 -area of DAB - area of CEB.
Area of DAB = (1/2)s^2.
Area of CFB = (1/2)bh = (1/2)((1/2)s)s = (1/4)s^2.
Area of CFB also = area of EFB + area of CEB.
Let x be the altitude of EFB (from E to line FB). Observe that x is also the altitude of CEB since each altitude is perpendicular to the perpendicular sides and each is drawn from a point (E) on the diagonal to each of the perpendicular sides.
So 1(/4)s^2 = (1/2)((1/2)s)x + (1/2)sx = (3/4)sx
So x=(1/3)s
So area of CEB = (1/2)s(1/3)s = (1/6)s^2.
Therefore area of DEC = s^2 - (1/2)s^2 - (1/6)s^2.
Re: Correct!
Alex Y
Henry, I actually think your solution is the most elegant. Many paths to the same result!
