Friday Puzzler --Track Meet
Alex Y
Alan, Ben, and Carl participate in a three-man track and field competition. Points are awarded for first, second, and third place, with the same point values for each event. I.e., x points for first place, y points for second and z points for third, with x>y>z>0. No fractional points and no ties on any event.
Alan won the meet with 22 points.
Ben won the javelin, and ended the meet with 9 points.
Carl also ended the meet with 9 points.
Who placed second in the 100-meter dash?
No credit for an answer with no explanation; I'd just assume you flipped a three-sided coin. ;)
Credit to Stephen T.
Re: Friday Puzzler --Track Meet
Larry Barrett
You do not say how many events there are, so that is another variable.
As an example, if there are just three events, and if B wins the javelin and comes in third in the other two, then the most x can be is 7 and the least z can be is 1. B wins the javelin and places third in the other two for 7+1+1=9 points. If C places third in the javelin for 1 point, and comes in second in the other two then in order for C to have 9 points, 2y must equal 8, or y=4, so C will have a total of 1+4+4=9 points. A wins the other two events and places second in the javelin for 7+7+4=18 points. Not enough points for A. And by observation, any other set of values for x, y, z would have fewer points for x and would result in a lower score for A.
So there must be more than three events. With 4 events, the most x can be is 6 and the least z can be is 1. B would have to come in third in the other three events for a total score of 6+1+1+1=9. C could come in second in three events and third in the javelin. But then 3y would have to equal 8; y would not be an integer so this set of values does not work. And any lower value for x would mean that A could not reach 22 points.
With 5 events, the most x can be is 5 and the least z can be is 1. B wins the javelin and comes in third in the other 4 events for 5+1+1+1+1=9 points. A wins the other 4 events for a total of 4x5=20 points. If A comes in second in the javeiin and y=2, then A has 22 points. That means C comes in second in the other 4 events, including the 100 yd dash, and third in the javelin for a total of 2+2+2+2+1=9 points, which satisfies all the point totals.
I think this is one solution. There may be others.
I vaguely remember from an algebra class that equations for which the only solutions are integers are called diophantine equations. This may be an example of a problem where a diophantine equation could be derived involving x,y,z and n. Or, Alex will come up with a clever way of looking at this that makes the solution obvious.
Correct!
Alex Y
Nice job, Larry.
No AHA! solution for this one :-(
One shortcut is to observe that 40 points were awarded, so the number of events times the points per event = 40. You can narrow the possibilities by observing that the number of points is at least 1+2+3=6. That leaves possibilities of 8 points in each of 5 events, 10 points in each of 4 events, 20 points in each of 2 events, and one event with 40 points. You can pretty quickly eliminate the one and two event cases, and get to the solution you found.
I stumbled at the very last stage--saying that A had one second place and C had 4, but how could you tell which one got second in the 100-yard dash? Had to give myself a dope-slap when it was pointed out that the only one A didn't win, so could have placed second in, was the javelin.
