Friday Puzzler II -- another sequence
Alex Y
In most sequence problems, you try to determine the "rule" used to create the given sequence, and apply that rule to determine the next item in the sequence. The sequence is usually long enough that one rule stands out as the only plausible one.
This problem is a little different -- you are guessing a fourth number, and I will tell you whether or not the four numbers follow the rule. It is like the old game "twenty questions". You keep trying numbers until you think you have the rule.
Here are the first three numbers, which follow the rule:
1, 2, 4
I don't know how well this will work, since I am not on the site constantly. But just post your candidates for the fourth number and I will give each a yea or nay.
