Fridqay Puzzler -- More clamps
Alex Y
This time there is a stockpile of clamps in a warehouse, and the owner of the clamps has said they are free for the taking. However, the warehouse also has other valuable items, and is protected by seven fences. Each fence has a guarded gate, and while the guards are supposed to let clamps through, they are known to demand a bribe. In particular, each guard requires you to turn over 1/2 of the clamps you have when you get to his gate, then returns one to you as a gesture of good will. If you show up at a gate with an odd number of clamps, the guard will just take them all.
What is the minimum number of clamps you must take from the warehouse in order to have something left when you get through all the gates?
Bonus question:
This puzzle originally appeared on Car Talk. Besides modifying it from mangoes to clamps, I have changed it to ask for the minimum number. Click and Clack were appropriately raked over the coals for suggesting that the answer they gave (which was the minimum) was the only solution. For extra credit, what is the general form of possible number of clamps that would let you get through these gates?
Re: Fridqay Puzzler -- More clamps
Larry Barrett
I heard the CarTalk show where C&C talked about their answer and the letter they received, so I will leave that part of your Puzzler to others.
But here is my solution to the extra credit question.
Suppose you want to end up with n clamps after you leave the guard at gate 7. This means that when you arrived at gate 7 you had to have 2(n-1) clamps. You kept (n-1), gave the guard (n-1) and the guard gave you 1 back, so you left with n.
Now go back to gate 6. You would have had to arrive at gate 6 with 2[2(n-1)-1] clamps. Keep 2(n-1)-1, give the guard 2(n-1)-1, get 1 back, and you leave with 2(n-1).
The pattern now looks like this:
Arrive at gate 7 with 2(n-1) = 2n-2 = 2^1n - 2^1.
Arrive at gate 6 with 2[2(n-1)-1] = 4n-4-2 = 2^2n - 2^2 - 2^1.
If you trust your extrapolation instincts, this means you
Arrive at gate 5 with 8n-8-4-2 = 2^3n - 2^3 - 2^2 - 2^1,
Arrive at gate 1 with 2^7n - 2^7 - 2^6 ... - 2^1.
If you remember HS (maybe college) math, the last terms can be rewritten as
(2^8 - 2), so the general form of the number of clamps that you need when you arrive at gate 1, in order to leave gate 7 with n, is
2^7n - (2^8 - 2).
For example, if you want to leave gate 7 with 3 clamps, you need to arrive at gate 1 with 128*3 - (256-2) = 130.
Correct for extra credit!
Alex Y
You found the key to solution -- to work backwards. The "guard function" at each gate is g(n) = n/2 +1. But that is only defined for even numbers, and it is hard to find the domain of repeating that function 7 times. But the inverse of the guard function (call it "f") is easier to work with. f(x) = (x-1)*2 is defined for any positive integer.
As you pointed out, repeating this function 7 times tells you what you need to start with to come out with any particular x at the end
I originally read your answer on my phone, and didn't recognize it, since we had two very different looking versions of exactly the same answer. I remembered my answer of 128*(n-2) + 2, and didn't realize ours were the same answers until I got back to some paper and pencils!
