Friday Puzzler -- More Odd Dice
Alex Y
Two traditional dice can be thrown and the results added to determine a number from 2 to 12, with a 1/36 chance of 2, a 1/36 chance of 12, a 1/18 chance of 2,...
Can you design two different six-sided dice, both of which have a positive whole number on each face, and that when added will give exactly the same probability distribution as standard dice?
Note, I emphasize "positive" above, lest you mistakenly read it, as I did, as "non-negative". If zero were allowed, the answer would be trivial--number one die from 0-5 and the other from 2-7
