Friday Puzzler -- Tricky Dice
Alex Y
This week's puzzle is to design a special set of three dice. These dice have the unusual property that whichever die you opponent chooses, you can pick one of the remaining two that give you a better-than-even chance of beating your opponent in a roll of the dice.
1) Each face of each die has a single digit from 1 through 9 (and yes, you can distinguish between the 6 and the 9)
2) Opposing faces are marked with the same digit
Followup questions (that I do not have the answer to): What are the best odds you can give yourself in such a set of dice? If we remove the restriction that opposing faces are the same, can you design dice that give you a better chance of winning (assuming your opponent will choose the die that gives him the smallest chance of losing)?
