Friday Puzzler -- Matchsticks
Alex Y
This one is shamelessly taken from CarTalk, with a challenge to come up with other answers.
Seven matchsticks are arranged to form the following incorrect equation:
VII=I
The challenge is to move one matchstick to make this true.
There is one solution that Click and Clack had in mind, but they said their producer Dougie had another solution. They also volunteered that they were not looking for solutions that created an inequality sign.
So, can you find:
The solution they were looking for
Dougie's solution
Other possible solutions (I think with a little creative interpretation or stretching, there are others.)
Re: Friday Puzzler -- Matchsticks
Larry Barrett
Remove one leg of the V, insert between the II and rotate 90* to become a minus sign: \ I-I=I.
John Veerkamp
6 not equal to 1
John Veerkamp
6 greater than 1
I don't get it
Alex Y
what does "/1-1" represent?
True
Alex Y
That is the inequality that Click and Clack said they weren't looking for, but it is a true statement.
I don't see it
Alex Y
How do you make VII=1 into 6>1 by moving only one matchstick?
Re: I don't get it
Larry Barrett
Well, "with a little creative interpretation or stretching" /I-I=I can be intrepeted as II-I=I.
Re: I don't get it
Alex Y
Okay, that puts a new slant on it. ;)
Re: I don't get it
Larry Barrett
Since you let me get by with that one, here's another:
Remove one leg of the V, superimpose it on top of the adjacent I to form
\XI=I; that is, 1 x 1=1.
good one
Larry Barrett
How about taking the last I from VII and laying it horizontal across the VI, using it as the symbol for 'divide'. (I use --- to represent the 'divide' symbol below). Might be a stretch.
\ /I
--- = I
VI
You are very close
Alex Y
to the answer they were looking for (the "right" answer). However, I don't know where you found all the extra matchsticks for your answer. ;)
Re: I don't see it
John Veerkamp
should have said 7 greater than 1. Take one of the = match sticks and place it at an acute angle to the other. Greater than signs often have one leg horizontal and only one leg slanted.
Another good one
Alex Y
And using the same reasoning, you could make 6 greater than or equal to 1
Gets my vote
Henry Higginbotham
I find the usual solution a bit radical for my tastes. John's answer is simple and elegant, even if not equally pleasing.
We have a winner!
Alex Y
I believe Henry has alluded to the "correct" answer that Click and Clack were looking for.
We still haven't found the one Dougie came up with (an equation, using standard mathematical operations).
Some Answers
Alex Y
VII=I
The answer Click and Clack were looking for, as found by Henry:
Move the second I in "VII" (a popular one to move in many answers) and place it horizontally above the other I, so that it and the V form the square root symbol. sqrt(1)=1
Other Arithmetic Equalities, involving some misalignment:
Dougie's answer: Move that same I in front of the VI, but below it, so that it reads 1 raised to the sixth power = 1.
Larry's solutions involving a slanted one: /I-I=I and \XI=I
True statements that are not equalities
John's inequality VII>I where the bottom of the > is horizontal
Any number of "not equal to" versions.
True statements in their context
A Roman school child who couldn't remember how to convert from units to dozens might write on his palm XII=I
And IVI=I is true in the predicate calculus, whether taking I as a variable, or the convention of 1=True. I or I = I.
Thanks to all for playing.
A tough one with no math beyond simple arithmetic coming tomorrow.
