Friday Puzzle -- Jabberwock
Alex Y
Okay, this really doesn't have anything to do with Slithey Toves or other such, but it is by Lewis Carroll.
I am sitting in a circle with some friends. I have the most money of any of the people in the circle (we all have a whole number of dollars). The person to my left has $1 less than I, and the person to his left has $1 less than he, etc. all the way around the circle.
I pass a dollar to the person to my left. He then passes two dollars to the person to his left, and this continues around the circle until eventually one person is not able to make the required pass. At that point, the process ends, and everyone compares their funds. There are two individuals sitting next to each other in the circle, one of whom has 4x as much money as the other after all this passing.
How many people are there in the circle?
How much money did the poorest person i the circle start with?
Re: Friday Puzzle -- Jabberwock
Larry Barrett
The initial poorest person started with the same amount that the initial richest person ended up with. And the number of people in the circle is one more than that number.
  I don't think so
Alex Y
Ad least that doesn't match Rev. Dodgson's answer, and I can't see an answer in which that would be true.
Question
Larry Barrett
Is this the correct interpretation of the problem?
Suppose there are 4 players, A, B, C, D, and A starts with 6 dollars, B with 5, C with 4, D with 3.
Round 1. A gives 1 to B, B then gives 2 to C, C gives 3 to D, D gives 4 back to A.
So after Round 1, A has 9 (6 - 1 + 4), B has 4, C has 3, D has 2.
To start round 2, A then gives 5 to B, B gives 6 to C, C gives 7 to D, D gives 8 to A.
So after Round 2, A has 12, B has 3, C has 2, D has 1.
This continues until one player, after receiving $$ from the player on his left, and adding that to what he has, does not have enough to pass on to the player on his right.
Correct
Re:   I don't think so
Larry Barrett
After further scratching of my head and several more back of the envelopes, I think there are 7 in the circle. If you multiply the amount the poorest person in the first round started with times the amount the richest person in the first round ended up with in the last round, it is half what the richest person in the last round ended up with.
That's better
Alex Y
Lewis Carroll presents a solution that is pretty straight-forward high-school algebra. The setup is not that easy to come up with, though.
Actually, he solved directly for the two numbers the puzzle asks for.
I think one paradigm shift makes it immensely easier: imagine a basket that is passed around, with each person adding a dollar before passing it to the next. Adding that little bit of wicker clearly doesn't change the substance of the problem, but it makes it a lot easier for me to see the solution.
Solution
Alex Y
M people in the circle
$k held by the poorest person at the start.
I start with M+k-1 dollars.
After k complete rounds, everyone is $k poorer, except for the person holding the pot. The pot being passed from the poorest person to me has Mk dollars in it. The poorest person has $0 after making this pass, and I have M-1 dollars before accepting the pot.
It is obvious at this point that the person to my right, who now has $0 will not be able to add to the pot on the next round, so the process will stop after M-1 more passes.
At that point, I will have M-2 dollars, and the originally poorest person will have Mk+M-1. It's pretty easy to convince yourself that the only 4:1 ratio possible is between the originally poorest person and me. So
Mk +M -1 = 4*(M-2)
Mk =3M -7
k=3-7/M
And the only non-negative integral solutions to that are k=2 and M=7
