Friday Puzzler -- Explorer on a walk
Alex Y
You are told that you need to set up a communication link with Explorer Bob during his daily travels. You can set up your communication station wherever you want, and you can buy whatever radio equipment you need for the communication. However, the cost of that equipment goes up in proportion to range, so you want to position your station so that you can use the least powerful radio possible to establish communication.
Unfortunately, you are not given the location of Bob's base camp. All you are told is that every day he leaves his base camp, walks south for one mile, Then while taking his samples and making observations, he walks east one mile. At the end of the day, he heads north one mile and finds himself back at camp.
Where do you set up your communication station?
Re: Friday Puzzler -- Explorer on a walk
bill earl
At Bob's base camp :D
Maybe
Alex Y
but you are not told where that base camp is. :(
Re: Maybe
bill earl
But the question as stated is ambiguous.
Is he using a compass or a GPS to navigate?
Either way, the scenery is probably pretty much the same.
Re: Maybe
Alex Y
Either one. Let's say GPS.
True.
But still, his base camp may not be the ideal location, even if you knew where that base camp was.
Re: Maybe
bill earl
Assuming that Bob's movements are restricted to the Earth's surface, the daily S-E-N expeditions of Bob are only possible in one coordinate system. And (without further clarification) the ideal radio location would be at the origin of that coordinate system. The question is, where is the origin of that coordinate system?
If he is using a GPS rather than a compass, that would imply the northernmost intersection of the lines of longitude.
Re: Maybe
Larry Barrett
If Bob's actual path was always the same, then a transmitter located at the center of the spherical triangle would require the least power. Of course, if his origin is as you point out, then Bob's route would not necessarily be the same each day.
Another possibility, albeit requiring a little navigational license, would be if Bob's base camp was 1 mile north of the southernmost intersection of the lines of longitude. He would then travel 1 mile south, march in place for the equivalent of a mile, turning to the east with each step, then return to his base camp. The transmitter would be located at the midpoint, 1/2 mile south of the base camp.
Re: Maybe
Alex Y
Good assumption.
Are you sure about that?
Re: Maybe
Alex Y
No, no marching in place. He actually travels east for one mile.
At the north pole
charlie belden
which is where his base camp is
Re: Maybe
bill earl
If you knew which meridian upon which Bob set out upon each morning, you could refine the location. But without further clarification, you have to assume that he could choose any heading from 0-360 degrees. From the information provided so far, we know that the geographic north pole is the center of Bob's possible range.
Re: Maybe
Larry Barrett
If 'marching in place' is not allowed, there is another location, X, for Bob's base camp not far away that will work. Point X is located a little more than 1 mile north of the southernmost intersection of the lines of longitude (S pole) such that when Bob walks 1 mile south he reaches point Y. He then turns to the east and walks 1 mile, bringing him back to point Y (he circumnavigates the earth on this 1 mile walk), and he then turns north and walks 1 mile back to his base camp at point X. The distance from Y to the S pole will be approximately the radius of the 1 mile circumnavigation circle; so Y will be approximately 1/6 mile north of the pole, and X will thus be approximately 1 1/6 mile north of the pole.
Correct!
Alex Y
While there is one location in the northern hemisphere for Bob's base camp, there are infinitely many possibilities near the south pole. In fact, there are even infinitely many latitudes at which he could set up his base camp. It is at 1+1/(2*n*pi) miles from the south pole, where n is a positive integer, the number of circles he makes during his eastward trek.
So the answer to the original question is that you need to set up your communication station very close to the equator (either a few yards north or south of the equator, depending on whether you have to be able to reach him at base camp or only on his eastward treks.
