Second Friday Puzzler -- leading digits
Alex Y
John was all over that last one, so maybe I better post another! This one is mathematical, but unlike the box puzzle, doesn't require extensive calculation or manipulation.
For some integers "n", 2^n and 5^n have the same leading digit. What are the possibilities for that leading digit?
Full credit : deducing the answer(s)
2/3 credit: using a computer to find n's for which this is true, and examining enough of them to convince yourself the you have all the possibilities, then coming on the "aha" that tells you why this is true.
1/3 credit: using the computer to find the answer(s), and just hoping there are no other answers for other values of n.
Re: Second Friday Puzzler -- leading digits
Larry Barrett
Any credit for deducing at least one of the answers and hoping there are no others?
Alex Y
Nah, if you've gotten that far, you are nearly there. Wouldn't want to give part credit and dissuade you from keeping at it! ;)
Jim Rutten
I'll take the low hanging fruit and say zero and one would fit the bill.
Alex Y
Conventional representation of integers prohibit zero from being the leading digit.
Can you give an "n" for which 2^n and 5^n both begin with 1?
Bill Earl
I believe the conventional definition of integers includes zero. And that x^0 for any x is 1. So I'm with Jim on that one.
As for others... Still working on that.
Alex Y
Double "doh" on my part, and apologies to Jim.
My statement of the problem should have said "for some positive integers n"
But as stated, I agree that 1 works for n=0.
Larry Barrett
The puzzle is asking for the "possibilities for the leading digit" - that is, where the leading digit of 2^n and 5^n are the same, for integer values of n.
I think the answer is 1 and 3, which occur when n=0 and n=5.
My approach so far has been to look at the binomial expansion of (2^2 - 2)^n and (2^2 + 1)^n, but no aha's so far.
Jim's got the first one
Alex Y
n=0 gives 1 as the leading (and only) digit of 2^n and 5^n.
Larry has identified another
Alex Y
2^5 = 32
5^5 = 3125
Both have a leading digit of 3
Can anyone find another or say why these are the only possibilities for the leading digits?
Re: Larry has identified another
Jim Rutten
First, I want to admit to totally cheating on this. I created a spreadsheet. In the first 100 positive integers I found 5 that I believe qualify for the answer. Besides 5 which was already identified, I found 15, 78, 88, and 98 met the criteria. Interestingly, 108 and 118 also qualified. I believe the ultimate answer to this is an infinite amount of answers but I find it facinating that the answers appeared to be grouped in chunks around the last digit (the 5 in 5 and 15 and the 8 in 78, 88, 98, 108, 118). I numbered my spreadsheet all the way to 500, but my eyes got tired.
Alex Y
Not cheating at all. But remember the question is not to find the "n"s, but rather whether there are limited number of possibilities for the first digit, and if so, why. Do you have any conclusions about the first digits?
I agree that there are almost certainly an infinite number of n's for which 2^n and 5^n share the same first digit. And I agree that 5,15, and 78 are the first three non-zero n's for which this is the case (I didn't look any further, but understand why the pattern you see on final digits of the n's is likely to occur.)
Larry Barrett
Jim, this isn't 'totally cheating', this gets you 1/3 credit (at least). I did the same thing, after giving up on deducing the answer. I found the same sets of exponents you did, and more. They all result in the same leading integer for 2^n and 5^n, namely 3. If you look at the leading integer pattern where the exponent is n-4, n-3, n-2, and n-1 for the cases you found you will see essentially the same repeating pattern. But it is not completely predictable, and doesn't repeat in exactly the same way.
It is tempting to say that 3 is the only possibility where 2^n and 5^n have the same leading integer, but I can't prove it.
Why three?
Alex Y
Larry speculated correctly that 3 is the only possible shared leading digit for n's greater than 0, and Jim surely saw the same with the number of cases he identified.
But why is that the case?
Re: Why three?
Bill Earl
Why indeed.
I took a few minutes and wrote a program to crank out a few more examples. It appears to confirm the '3' hypothesis. At least within the limits of double-precision math.
Not sure if it has anything to do with the question, but the grouping of 'n's is interesting:
0: 1 1
5: 32 3125
15: 32768 30517578125
78: 3.02231454903657E+23 3.30872245021211E+54
88: 3.09485009821345E+26 3.23117426778526E+61
98: 3.16912650057057E+29 3.15544362088405E+68
108: 3.24518553658427E+32 3.08148791101958E+75
118: 3.32306998946229E+35 3.00926553810506E+82
181: 3.06499108173178E+54 3.26265223399926E+126
191: 3.13855086769334E+57 3.1861838222649E+133
201: 3.21387608851798E+60 3.11150763893057E+140
211: 3.29100911464241E+63 3.03858167864314E+147
274: 3.0354201441027E+82 3.29443685725954E+191
284: 3.10827022756117E+85 3.21722349341752E+198
294: 3.18286871302263E+88 3.14181981779055E+205
304: 3.25925756213518E+91 3.06818341581108E+212
367: 3.00613450595051E+110 3.32653112500637E+256
377: 3.07828173409332E+113 3.24856555176403E+263
387: 3.15216049571156E+116 3.17242729664456E+270
397: 3.22781234760864E+119 3.09807353187945E+277
407: 3.30527984395124E+122 3.02546243347603E+284
Re: Why three?
Larry Barrett
Look at the pattern of leading digits between the cases where 3 is the leading digit (eg 201 and 211). The pattern is the same in these examples. Note that 221 is almost another case with leading digits = 3. It seems to be a repeating sequence every 10n, starting at 5. But not quite 10n. It makes me wonder if 3 is really the only answer.
n.....2^n..............5^n
201 3.21388E+60 3.1115E+140
202 6.42775E+60 1.5558E+141
203 1.28555E+61 7.7788E+141
204 2.5711E+61 3.8894E+142
205 5.1422E+61 1.9447E+143
206 1.02844E+62 9.7235E+143
207 2.05688E+62 4.8617E+144
208 4.11376E+62 2.4309E+145
209 8.22752E+62 1.2154E+146
210 1.6455E+63 6.0772E+146
211 3.29101E+63 3.0386E+147
212 6.58202E+63 1.5193E+148
213 1.3164E+64 7.5965E+148
214 2.63281E+64 3.7982E+149
215 5.26561E+64 1.8991E+150
216 1.05312E+65 9.4956E+150
217 2.10625E+65 4.7478E+151
218 4.21249E+65 2.3739E+152
219 8.42498E+65 1.1869E+153
220 1.685E+66 5.9347E+153
221 3.36999E+66 2.9674E+154
The "near periodicity"
Alex Y
of the threes coming up is because 2^10 ~= 1,000 and 5^10 ~= 10,000,000 Thus the threes come up every ten n's, until it goes "off cycle", and it takes a while (15 to 78 eg) to come back around, then it's every ten again for a while.
Re: The "near periodicity"
Larry Barrett
That explains the 3. But the other possibility for same leading digit would seem to be 1; e.g. as you point out, 2^10 ~ 1000 and 5^10 ~ 10000, and the leading digit is 1.
Here are the next in the series:
2^10 ~ 1.024 x 10^3, 5^10 ~ 9.76 x 10^6
2^20 ~ 1.048 x 10^6, 5^20 ~ 9.53 x 10^13
2^30 ~ 1.073 x 10^9, 5^30 ~ 9.31 x 10^20
You can see that the leading digit for 2^10n is slightly more than 1 and is increasing, while the leading digit for 5^10n is slightly less than 10 and is decreasing. If it were slightly less than 10 but increasing I think for some n they would have the same leading digit (1), but looks like that is not the case.
Hint
Alex Y
Bill has provided a large list of 2^n and 5^n that share the same first digit. Examine those and you will see that those pairs (other than n=0) are defined by a condition that is stronger than the same first digit.
Big hint
Alex Y
What is the product of the two numbers you are finding?
Re: Big hint
Larry Barrett
THAT is a pretty good hint; I couldn't see the forest for the threes.
