Monday
Monday
Monday
Gary Smyth
From 1830 until steam took hold well into twentieth century, even through the 1930�s, wood merchant ships not only became larger but also put more and more sail on their ships. The large square rigged boats of the Pacific Northwest often carried four masts and up to 43 sails flown on, in front of, between, and after a mast. The main mast usually carried six but could support eight sails. Today�s trivia. Name the sails, bottom to top, supported on the main mast of one of the large square rig iron and lumber ships.
Re: Monday
Re: Monday visual help
Gary Smyth
This may help in visualizing today's trivia. Numbers 21-28.
Re: Monday
Dale Lenz
Six sail
Dale Lenz
from bottom to top
1 Main Course
2 Main lowest top
3 Main upper top
4 Main lower top gallant
5 Main upper top gallant
6 Main Royal
Thanks for the ? Gary.
Re: Monday
since no one has finished answering
Gary Camp, Bend Oregon
27(7) Skysail
28 (8) Moonraker or moonsail Admittedly I looked them up, The question takes one in many interesting directions. Thank youy
Re: Monday
Re: Monday answer
Gary Smyth
Dale and Gary get kudos and large gold stars. I thought that no one wanted a shot at this one. By the way, If participants know the answer outright to my trivia, good on ya. If you care to spend more time and look it up that's fine too. It's trivia after all. All I ask is that the box is observed for early responders and if you choose to obfuscate to keep the thread alive that's part of the fun. Your creativity keeps me on my toes. Just be prepared to answer directly if you want credit at the end.
Monday Sail answer. From bottom to top
21 Main course
22 Main lower topsail
23 Main upper topsail
24 Main lower top gallant
25 Main upper top gallant
26 Main royal
27 Main skysail
28 Main moonsail (and a luscious name "moonraker")
The moonsail is so high and required no small effort to set that it may be one of several early derivations of the saying "Shoot the moon"
Re: Monday
Remember where you found the top two?
Gary Smyth
I found only one source and illustration. Just curious to locate a different reference source. Thanks
Re: Monday
Re: Remember where you found the top two?
Morning Gary, first place I found was http://en.wikipedia.org/wiki/Square_rig then after your question today I went looking some more here is another reference, although it is a wiki also http://en.wikipedia.org/wiki/Sail-plan Then I found one more although it only mentions the the skysails and moonrakers by name http://museum.gov.ns.ca/mma/AtoZ/rigs.html. thanks again for the question. It is fun to poke around Pacific Northwest history
Re: Monday
Dale Lenz
Testing new password
Re: Monday
Dale Lenz
Works, :")
