Friday Puzzle -- dime, then cork?
Alex Y
I've seen this done as an actual physical puzzle; hopefully it will be fun to try to solve as a mental puzzle.
The setup is a perfectly ordinary empty wine bottle, dime, and cork from the bottle.
The dime is dropped into the bottle, and the cork is inserted to stopper the bottle. So the bottle now has a dime rattling around in it, and is sealed with a cork, just like a full wine bottle is.
The challenge is to remove both the dime and the cork from the bottle, IN THAT ORDER. I.e., before removing the cork, remove the dime; then remove the cork.None of the cork, dime, or bottle can be altered in the process.
Re: Friday Puzzle -- dime, then cork?
Don Orr
Does the cork need to remain intact?
I can do it but I decline
Gary Smyth
if even a drop of champagne was lost in the process.
Steven Antonucci
Corks can go in too
1/2 way there
Alex Y
Steve's got the tricky part about how to free the dime. Now how do you get the cork out?
Remember, it has to be a straight
Gary Smyth
(not champagne style) cork. None of this works with a mushroom top cork. I've won freedom from the bar bill on more than one occasion with this trick. OK, The cork is in, the dime is out. Cork is about 50% air -- which is why you can't recork a half full wine bottle and keep it fresh for more than a couple of days. Take a plastic bag or even a cloth napkin and insert it into the bottle about half way or a little more. Turn the bottle upside down and "catch" (surround as much as possible) the cork in the folds of the napkin. Pull the cloth out and the cork will come too. If using a plastic bag (my favorite) insert the twisted bag but leave the open end of the bag outside the bottle. Catch the cork. Blow into the bag to inflate it slightly. Pull them releasing the air in the bag as you pull both out of the bottle.
