Friday puzzler -- make-up for last week
Alex Y
Sorry for going AWOL last week. Lee was all over that last one, so let's try a little harder one.
You need to find three 5-digit perfect squares such that:
1) only five digits are used among them (but with repeats and missing digits permitted in any one number)
2) each of the five digits is the count of the number of times another digit appear in the three numbers. None of the digits refers to its own count. I.e., if there are 3s and 7s in the answer, it is possible that "7" appears three times, but "3" does not appear three times.
3) if I told you which digit appeared only once, you would be able to deduce the answer.
But I won't tell you which digit appears only one time, and you can still deduce the answer!
Re: Friday puzzler -- make-up for last week
Hints
Alex Y
A spreadsheet will let you quickly generate all 216 five-digit perfect squares.
From the first two properties given in the puzzle, you can derive another property that lets you quickly whittle the list of candidates down to nine. (Or if you find that property first, you could use the spreadsheet to calculate only 72 candidates, and quickly visually inspect them to find the nine possibilities.
Will start the discussion
Dan Donaldson
We know that the answers cannot contain a 0 because of the counts.
Good start
Alex Y
And while that seems obvious once you state it, it totally eluded me for the longest time as I solved this!
Re: Good start
Larry Barrett
And I believe the group of three perfect squares has to have at least one 1, because of clue 3, and it has to have more than one 1 because of clue 2. Furthermore, the last digit in each of the three 5-digit perfect squares must be a number from this set: {0,1,4,9,6,5} since every square ends in one of these (and Dan eliminated 0).
Another criteria
Dan Donaldson
We know 0 cannot be one of the digits, but we also know that the 5 digits must be 1,2,3,4,5 because each one represents the number of another and the sum of 1-5 is 15, which is the total number of digits in the three answers.
The 9
Dan Donaldson
Here are the 9 taking out all of the 0's and numbers greater than 5
35344
34225
12544
52441
33124
13225
21316
12321
14161
Re: The 9
Larry Barrett
Double check your list, but what you have includes a set of three that satisfy the criteria.
Re: The 9
Dan Donaldson
OOPS, that is what I get for doing stuff like this at 3 in the morning. ;)
Getting there!
Alex Y
No 0's and Sum of digits = 15 -> digits are 1,2,3,4,5 is the corollary of the first two conditions that let you narrow the candidates to 9.
Re: Getting there!
Larry Barrett
My answer has 3 1s, 5 2s, 4 3s, 2 4s, and 1 5. I did not check to see if there are other combinations.
Alex Y
Kudos to Dan and Larry for the cooperative effort to get this one!
The unique solution is indeed 12321, 33124, 34225.
