Friday puzzle -- left and right
Alex Y
You are given four letters and four digits in the following position:
ABCD_1234
Your goal is to get to this position:
1234_ABCD
With the following restrictions:
1) Letters can only move to the right, and digits only to the left.
2) The only allowable moves are to an adjacent empty spot (and the space above is only one character wide), or jumping over one character to that empty spot.
Your answer can just be a list of letters and digits in the order moved
Re: Friday puzzle -- left and right
Correction
Alex Y
My second rule was slightly mis-stated:
Should say "an empty spot." You can jump the last one in line even if there is another empty spot internal to the list of digits and letters.
Sorry if that caused any confusion.
Get out those coins!
Alex Y
I'm not sure what to make of the deafening silence on this one. The source I got it from listed this as an easy puzzle, and maybe everyone thought this was too easy to deserve a reply. Or maybe you are like me and found this tricky (in my case, despite having solved it may times in the past).
Anyway, get out four pennies and four nickels, or some checkers, different colored paper clips, etc., and see if having a physical implementation will help. The version I had as a kid was wooden, with 11 "dents" in a row, and five white and five black marbles.
Re: Correction
Larry Barrett
I did work on this a little over weekend. My usual way is to try a simpler problem to see if there is a pattern that can be extrapolated.
So,
A_1 is trivial
AB_12:
AB1_2
A_1B2
A_12B (is this what you mean by your correction?)
A1_2B
_1A2B
1_A2B
12_AB
Before trying next level, want to make sure I understand the rules.
Re: Correction
Alex Y
An often-helpful problem-solving technique, to which this problem will yield.
So,
A_1 is trivial
AB_12:
AB1_2
A_1B2
No. From A_1B2, the only legal moves are to _A1B2 and A1_B2.
And thinking about the version I had as a kid, my "correction" is unnecessary (not wrong, but probably confusing and possibly leading one astray). Better just to think of nine positions for the four letters and four numerals.
BTW, your first two moves, getting to A_1B2, are correct for the "level 2" puzzle.
Re: Correction
Larry Barrett
OK
AB_12
AB1-2
A-1B2
-A1B2
1A-B2
1A2B-
1A2-B
1-2AB
12-AB
and for the 3 level
ABC-123
ABC1-23
AB-1C23
A-B1C23
A1B-C23
A1B2C-3
A1B2C3-
A1B2-3C
A1-2B3C
-1A2B3C
1-A2B3C
12A-B3C
12A3B-C
12A3-BC
12-3ABC
123-ABC
Correct for 3
Re: Level 4
Larry Barrett
ABCD-1234
ABCD1-234
ABC-1D234
AB-C1D234
AB1C-D234
AB1C2D-34
AB1C2D3-4
AB1C2-3D4
AB1-2C3D4
A-1B2C3D4
-A1B2C3D4
1A-B2C3D4
1A2B-C3D4
1A2B3C-D4
1A2B3C4D-
1A2B3C4-D
1A2B3-4CD
1A2-3B4CD
1-2A3B4CD
12-A3B4CD
123A-B4CD
123A4B-CD
123A4-BCD
123-4ABCD
1234-ABCD
If the above is correct, it is interesting that the solution for level 2 required 9 moves (including the starting position), the solution for level 3 required 16 moves, and the solution for level 4 required 25 moves.
Correct!
Alex Y
Looks right to me. The obvious mirror image solution starting with D also works.
This becomes easy, even for large numbers of pieces (16 checkers of each color in 33 spaces) if you follow the principle of moving as close as possible to alternating colors (or digits/letters) until you have them completely alternating, then move as many of one type, then the other toward their objective.
Interesting observation of the squares. I wonder if the pattern of moves may help. Just listing the moved pieces, the solutions are:
1) 1A1
2) 1BA12BA2
3) 1CB123CBA123BA3
4) 1DC123DCBA1234DCBA234BA4
It looks like the number moves for n pieces per side is
3 moves of all n pieces at the middle of the solution, = 3n
At each end of the solutions, moves of 1+2+3+...+n-1 = (n-1)*n/2
So middle + 2 ends = 3n+(n-1)*n = n^2+2n = (n+1)^2-1, which when adding in the starting position is the same as your observation.
And I just did it with five alligator clips vs 5 paperclips, and got 36 positions, which I'll count as qed :)
QED indeed!
Larry Barrett
Very cool. Neat to discover hidden symmetry like this.
