Friday puzzle -- sequence
Alex Y
What is the next number in the following sequence:
3, 7, 12, 14, 16, 19, 21, 25, 30, ??
I found this one very hard, so I will plan to dole out hints over time. Then again. someone may see it right away; you just never know.
Re: Friday puzzle -- sequence
First hint
Alex Y
There is no mathematical formula (at least to my knowledge) for deriving the next element of this sequence from those that have gone before.
Re: First hint
Jim Rutten
"Friends, Romans, countrymen, lend me your ear...and I will keep it for two score and one year and then return it.
Lizzie Borden took and ax and gave
Gary Smyth
her Mother forty wacks and when that job was nicely done gave her Father the correct number. Jeez w/o Jim's Shakespeare as a hint I'd have never made the association.
Solution *LINK*
Alex Y
Kudos to Jim. You are obviously a lot better at this than I; I expected to have to leave three or four clues before someone got on the right track.
The sequence in question is
III, VII, XII, XIV, XVI, XIX, XXI, XXV, XXX, XLI, XLV, LII, ...
numbers that when expressed in roman numerals take exactly three letters.
BTW, someone posted a link to a site that helps you cheat on these. But if you use it on one of these sequence puzzles, you are honor-bound not to spoil the fun for others, or claim that you have solved it. ;)
Someone has way too much time on their hands!!
The On-Line Encyclopedia of Integer Sequences�
Re: Solution
Dan Donaldson
I doubt that I would ever have gotten that one.
