Friday puzzle -- an ENIGMA
Alex Y
ENIGMA is a number in which the digits are
different and non-zero.
ENIGMA is divisible without remainder by E,
by the square NI, and by the cube GMA.
What is ENIGMA?
Source:
New Scientist magazine, 22 January 2011.
By Gwyn Owen
Re: Friday puzzle -- an ENIGMA
starting
Dan Donaldson
GMA must be one of:
125
216
343 (cannot be because not all unique)
512
729
NI must be one of:
16
25
36
49
64
81
E cannot be 5 because none of the gma possibilities end in 0 and 125 would be a dup.
Next? someone fill in the next blank ;)
Re: starting
Larry Barrett
Something I don't see yet:
The smallest GMA can be is 123; 123 cubed is 1860867 (a 7 digit number)
How can a 7 digit number divide into a 6 digit number evenly with no remainder?
Re: starting
Dan Donaldson
Not gma cubed, gma IS the cube. The same with the square. The word "enigma" is composed of a number (e) followed by a two digit square (ni) followed by a three digit cube (gma)
Clarification
Alex Y
Correct interpretation, and good start.
Re: starting
Larry Barrett
Thanks for clarification.
Since all digits are unique, there are only a few combinations of NI and GMA:
16729
36125, 36512, 36729
49125, 49216, 49512
64125, 64512, 64729
81729
Now add E to each, keeping in mind that if the last digit (the A) is odd, then E can not be even.
There are 29 possible combinations. I do not see any clever way to narrow it down further. A spreadsheet is your friend.
a bit more
Dan Donaldson
ni must be 36, 49, or 64 (why is left to the student ;-))
Come on, someone dig in also ;)
Re: starting
Dan Donaldson
729 cannot be it either
Re: a bit more
Dan Donaldson
Another couple:
e cannot be 1 or 2 and gma cannot be 729
Re: starting
Dan Donaldson
There are a few ways yet to simplify ;)
and the answer is...
Rob Scrimgeour
34912
typo?
Re: and the answer is...
Larry Barrett
Of the 20 or so possibilites left after Dan's work, the one that looked like it just had to be the one was 864512, and it almost works.
Rob has the answer but just a typo
Agree, but did not look like a good prospect
Good job, guys!
Alex Y
Rob's answer, with the addition of the missing digit, "5", is correct. 349125.
Dan's whittling down of the possibilities was correct. It could be carried just a little further, but then you have to resort to trial and error.
GMA = 125, 216, or 512, and
NI = 36, 49, or 64
Note that GMA divides ENIGMA if and only if it divides ENI000.
The lowest multiple of 512 that is also a multiple of 1000 is 128000. Other possibilities are 256000, 384000, 512000, 640000, 768000, and 896000. In none of these are the second and third digits a perfect square (and most are disqualified for other reasons as well).
Similarly, the lowest multiple of 216 that is a multiple of 1000 is 027000. Checking all the multiples of that, only 864000 has 2nd and third digits equal to one of our target squares, but doesn't work because of the 6.
So GMA must be 125, and since 8*125 = 1,000, ANY choice for ENI will satisfy the condition that ENI125 is divisible by 125.
So now, we have to test E = 3,7,9 and NI = 36, 49, 64. Eliminate the two possibilities with shared digits and you are left with only seven possible values for ENIGMA to test.
