Friday Puzzle -- A special magic square
Alex Y
A magic square is an array of numbers in which each column, row, and major diagonal add to the same total. For instance, in the following magic square:
25812
21528
18225
each row, column, and major diagonal adds to 45.
The puzzle for today is to determine what is special about this particular magic square. I think (but don't know) that this magic square is unique, except for reflections or rotations, in this special feature.
I think this is too hard without clues, so I'll post one clue right away, with another coming this evening. But if you can get it without using the clues, post your claim!
Re: Friday Puzzle -- A special magic square
Clue 1
Alex Y
The special property of the magic square in question involves another magic square.
Bill Earl
Would one need a digital computer to solve this?
Alex Y
I don't think so, but maybe I'm missing the implication. What did you have in mind?
Bill Earl
The property I am thinking of has to do with computations on digits (as opposed to numbers)
You may have found another property
Alex Y
Not the one I had in mind, but explain yours.
Re: You may have found another property
Bill Earl
The sum of the digits for each row, column and diagonal add up to 18.
David Weaver
Haven't tried to do anything with it yet, but interesting by inspection that every single row, column and diagonal is the same sum, making the sum of the outside of the box sides all identical.
Maybe that's a property of these in general, though.
David Weaver
Just read bill's last comment, only an hour late after he already said that! :\
Alex Y
I think that having a constant sum of digits is not very rare for magic squares -- basically, it says you have the same number of "carries" in each sum. For instance,
23 2821
222426
272025
shares that property, with the same sum of digits. The property I am looking for works only, I believe, for the given magic square and its seven reflections and rotations, at least among 3x3 squares with two or fewer digits.
Larry Barrett
It is interesting that only 4 digits are used: 1, 2, 5, 8.
And the numbers in the row and column associated with each corner use the same set of digits. For example, the numbers associated with the top left cell (25) are (8, 12) in the top row and (2, 18) in the left column. Same for all 4 corner cells, same for the center cell (15) and the remaining numbers in the center column and row (8, 22), (2, 28).
Clue 2
Alex Y
The other magic square referred to in clue 1 is
1056
3711
894
As a reminder, the magic square in the original puzzle is:
25812
21528
18225
Re: Clue 2
Larry Barrett
Subtract the second magic square from the first magic square, cell by cell.
Result is:
15 3 6
-1 8 17
10 13 1
A third magic square! and the sum of numbers (row, column, diag) for this square = 24, which is also equal to the difference between the other two squares: 45 - 21 = 24.
Re: Clue 2
Larry Barrett
Second thoughts - nevermind. Nothing remarkable about adding, subtracting magic squares.
Alex Y
Yeah, hard to imagine a pair of magic squares for which that doesn't work! ;)
But stick with the relationship between these two magic squares. BTW, it is a "one-way" relationship.
Final clue
Alex Y
This only works for English speakers
Answer
Alex Y
In this special magic square, if you write out every number in English, the letter counts of the words also form a magic square.
I speculated that this square was unique, except for rotations and reflections, but then limited that speculation to magic squares with two or fewer digits in each number. For instance, adding 300 to every member of this MS will lead to one in which "three hundred and" is appended to every English spelling of the numbers, adding a constant 15 to the word counts, leading to a MS.
