Humpday Triviola
Humpday Triviola
Humpday Triviola
Ok, you have a building project on your hands. Mostly outdoor or exposed wood is the nature of the job. Now to get your materials. It might be a good idea to check with the USDA for a EMC recommendation.
Why?
Re: Humpday Triviola
John Veerkamp
Is this another example of your dry sense of humor?
I think John has it, but just in case...
Lee Schierer McKean, PA
Only a balanced person with a dry sense of humor will get the golden uni today.
Lee
Re: I think John has it, but just in case...
Ken Oakley-Sunny St. Cloud, Fla.
Guess that leaves me high and dry---
John first in....answer
John was the first in with knowing that EMC relates to equilibrium moister content.
The MC of lumber can soar when is stored at a lumber yard without a protective cover and/or stacked over wet ground. Lumber stored in a very humid environment like next to the ocean can sponge water too. A KD stamping means very little if the lumber has been left sitting in the rain at a distribution center, reload yard, retail yard or building site. Spot check the lumber you are using with a moisture meter. It is important to match the MC of the wood you are using with the equilibrium conditions it will see in service. The in-service MC or equilibrium moisture content (EMC), can be benchmarked to relative humidity:
� RH 25% ~ MC 5%
� RH 50% ~ MC 9%
� RH 75% ~ MC 14%
� RH 90% ~ MC 20%
Wood used inside of homes as finished trim, cabinets and flooring, should be installed at a MC close to 8%. Wood used in exterior applications is a different story � it depends on where you live. In New England 14% MC is a good target. In Tucson, a 6% MC would be a better mark. The USDA Forest Products Laboratory in Madison has a pamphlet (FPL-RN-0268) listing outdoor EMC�s for about 350 cities worldwide.
Well done John, et al.
