Tuesday
Tuesday
Tuesday
Bill Earl
In many industrial processes, the value of the product produced can be measured in thousands of dollars per minute. Down-time of any kind is very expensive and every effort is made to minimize it.
One such process has a trimming step that involves a long continuous moving blade, much like a bandsaw. Replacing this blade takes approximately 20 minutes. Engineers at the plant tested many types of exotic, expensive blade materials and managed to achieve only incremental improvements in blade lifetime. One clever engineer came up with a simple, inexpensive solution that would double the life of any blade. What was it?
Re: Tuesday
Re: Tuesday
Alex Y
Did he borrow the idea from a German mathematician?
Is this for real?
Thanks for the puzzle.
Re: Tuesday
Re: Tuesday
Scott Blundell
It would seem that using a mob mentality, the service life could effectively be doubled.
Re: Tuesday
Re: Tuesday
Larry Barrett
I've seen conveyor belts like this, but not a cutting blade. Twice as many cutters - seems like a good idea.
Re: Tuesday
Re: Tuesday
Gary Smyth
How to obfuscate? Don't know. Teeth on both sides of the blade. Or eliminating the teeth and using a continuous knife edge on both sides with a self sharpener above and below the point where the product passes. In either case a half twist of the blade makes it a M_____ and there is only one side.
Re: Tuesday
Tuesday Answer
Bill Earl
As everyone figured out, a half-twist turns two edges into one yeilding twice the life from a 'Mobius' blade.
The application was in the food processing industry. And as you might imagine, a 40' long double-edged blade requires great care in handling.
