Monday
Monday
Monday
Gary Smyth
Sponsored in part by Porter Cable and Klingspor. The car is made 90% out of wood � exceptions, tires, transmission, motor, glass
The 15ft-long car has a laminated wood veneer chassis and wooden wheel rims inside giant 20 inch diameter tires.
Suspension is provided through laminated wooden arms and springs made from orange wood.
The entire car, which is made from a combination of maple, plywood and MDF, weighs just 2500 pounds - some 530 pounds less than the super lightweight Porsche.
The (semi) eco-friendly two seater, which is fitted with a six-speed, manual gearbox, can sprint from 0 to 60mph in just over three seconds. It gets 20 MPG. Top speed is projected at 240 MPH.
This is a look up. Who made this car? Where was it made?
Re: Monday
Re: Monday
John Veerkamp
I saw this in one of the wood working publications in the bookstore a few weeks ago , so I'll restrain myself.
Re: Monday
Is it a Ford "Woody"?
Re: Monday
Considering what Ford's thoughts
Gary Smyth
were when they launched the redesigned "new" Mustang, I can see that you possibly link this to the old GT40 of LeMans fame of the mid-to late 60's. But sadly, no. Not related.
1967 GT 40
Re: Monday
Re: Monday
John Veerkamp
I'll try not to splinter the group and keep Harmony
Re: Monday
I'm pleased.
Re: Monday
Monday answer
Gary Smyth
John is today's winner. A gold star for your forehead.
http://www.joeharmondesign.com/
The car is from North Carolina State. It is called the "Splinter". It was debuted in the autumn 2010.
Made by (older) student Joe Harmon who decided to design and build a concept car for his graduate project in industrial design, he opted to follow the supercar formula � creating a high-performance sports car that could compete with the likes of Ferrari, Lamborghini and Bugatti.
To make the project even more challenging, Harmon crafted the supercharged two-seater almost entirely out of wood.
"I want to show that you can make something really fast and really strong out of wood and that wood isn't an old and antiquated low-technology material," Harmon says. "Wood has its pros and cons, just like every other material does."
"Practicality is a minor deal," he says. "I don't know how many 700-horsepower supercars are practical. It's about style and performance and this car will have all that in spades. This car will not be a grocery getter."
If you did drive the Splinter to the grocery store, you'd have to shop light. The car won't have a trunk. But it will have many of the features you'd expect in a high-performance sports car, including a modified Cadillac Northstar 4.6 liter V-8 engine, twin superchargers, rack-and-pinion steering, anti-roll bar, and rear-wheel drive.
At 2,500 lbs., the car is about the same weight as a Mini-Cooper � but a lot faster. Harmon estimates it will be capable of hitting between 220 and 240 miles per hour. But he isn't just concerned with raw power.
"Top speed isn't something you should set a goal for; it's a byproduct," he says. "I don't want to sacrifice any drivability to try to get it to a magical top speed. I just want it to drive well and fast on a road course.
The wood used to make the car is composite material that is molded into various forms with a vacuum � much like carbon fiber � not carved or sculpted.
This process allows Harmon to combine sheets of paper-thin wood veneer to create the body panels and other parts to exact specifications. High-quality woods, like cherry and ash, will be used for the polished top layer; low-cost woods will be used underneath.
"The whole side of the car is one mold," Harmon says. "We'll likely lay that up as one piece of wood and cut the door out of that and match the grain going down the side."
Other parts aren't so easy to make. The suspension system, for example, presented a challenge at first, and the team almost opted to use metal.
"We talked about it and decided that a leaf spring was nothing more than a bigger, stiffer version of a longbow, so we researched bow making and came upon a wood called Osage orange," Harmon says. "It's the strongest wood found in North America, and it has properties that make it excellent for use in longbows."
Harmon is proud of the many innovations he and his team developed in designing the car. In addition to the novel suspension system, they developed a unique muffler and exhaust system to vent super-heated air out of the top of the car, and an innovative seating design to make room for the engine behind the driver, in the middle of the car. More info and photos during the build.
http://www.joeharmondesign.com (bottom -"building the splinter" - flicker, yes to view --photostream)
Re: Monday
Neat Trivia today, Gary!
