Tuesday puzzle
Alex Y
How many squares, of any size, can be drawn using the points on a 5x5 grid as the corners of the squares?
Tuesday puzzle
Alex Y
Re: Tuesday puzzle
John Veerkamp
Quick count = 30
Re: Tuesday puzzle
Alex Y
Come back after a slow count.
Re: Tuesday puzzle
Bill Earl
Coming at it from a different angle, I see 10 more.
Re: Tuesday puzzle
Jerry Glaser
I count 59 squares.
Re: Tuesday puzzle
Jerry Glaser
I miscounted. The answer should be 50.
31
Alex Y
That's the answer I get. You had me worried for a sec that I had missed nine!
Solution; all 50 shown
Alex Y
Congrats to Jerry for finding all 50 squares that can be drawn using these points. Below is an illustration, showing one example of each size square, and the count of those squares (from shifting horizontally and vertically, and in two cases by reflection):
Re: Solution; all 50 shown
Jerry Glaser
You should add 24 more squares to make the total 74! I did this by drawing 45 degree diagonals thru each point and getting 24 more squares. Try it.
Yes, but
Alex Y
are the corners of the squares points on the grid? I think not, if I am picturing correctly what you are doing.
And if you eliminate that requirement, then I suspect the answer is infinitely many squares!
