And one more
And one more
And one more
Alex Y
Find a five-digit number [distinct digits] that is the cube of the sum of its digits. I.e.,
(L+O+G+I+C)3 = LOGIC
Re: And one more
Re: And one more
Bill Earl
This one was pretty easy to code up. Without the unique digit constraint, there are five solutions which satisfy the mathematical constraints. Four of them have one or more leading zeros.
Re: And one more
Re: And one more
Larry Barrett
And of the five solutions, there are three with unique digits.
Re: And one more
Limiting the trials
Alex Y
I took a slightly different tack. Not being a programmer, I was limited to a calculator or spreadsheet. But I only had to test a few cubes, from the cubes of 22 to 35, since 22 is the smallest integer greater than cube root of 10,234 (the smallest five-digit number with unique digits), and 35 is 9+8+7+6+5, the largest possible five-digit number with unique digits. Of these 14 cubes, only two met the arithmetic test, and only one of those had unique digits.
273 = 19,683
Re: And one more
Re: And one more
Bill Earl
Hmm. You must have found a different set of solutions than I did. I only get one solution with 5 unique digits.
Re: And one more
Re: And one more
Larry Barrett
I also just used a spreadsheet. I found the same solution as Alex - 27 cubed = 19683
I also found 18 cubed = 05832, and 17 cubed = 04913. These seem like they work, but I have been wrong at least a couple of times before.
The other non-unique solutions I found are 8 cubed = 00512 and 1 cubed = 00001.
Re: And one more
My mistake
Bill Earl
There was an error in my program that omitted a couple combinations. The complete set is:
00000
00001
00512
04913
05832
17576
19683
The highlighted ones meet the uniqueness test. Alex can decide if leading zeros are permitted.
