Tuesday puzzle
Alex Y
Being a good short-order cook may be more complicated than you think!
Your task is to prepare three pieces of buttered toast as rapidly as possible. You have a two-door toaster oven that will hold one piece of bread on each side. The toaster oven toasts only one side of the bread, which must be flipped to toast the other side.
You are given the following times for individual operations:
Put a slice in one side of the toaster, remove a slice, or flip a slice: 3 seconds.
Butter a slice of toast: 12 seconds.
Toast one side of a piece of bread: 30 seconds.
The first four operations above can only be performed one at a time (i.e., you can't be removing a slice from one side while simultaneously putting a slice in the other side).
The bread is to be toasted on both sides and buttered on one side. It can only be buttered once the side to be buttered is fully toasted, but one side can be toasted after the other side is already toasted and buttered.
