Friday Puzzle -- How big a square
Alex Y
I drew a square whose sides were less than 80 units long.
Within the top left-hand quarter of the square I marked four points, each of which
was an integral, non-zero, number of units, not only from each side of the square but also from both the top left-hand corner and the bottom right-hand corner of the square.
How long was each side of the square?
Source: New Scientist magazine, 05 May 2010.
By Richard England.
Re: Friday Puzzle -- How big a square
David Weaver
OK...I'm busy drawing triangles. two of the points must belong to triangles with lengths 3, 4, 5
Trying to find the next size triangle where there is a relationship with x^2 + y^2 = z^2 with integers for all three.
David Weaver
The way I'm attempting to solve this (by putting together all integer solutions to the pythagorean theorem and then finding other solutions where legs the complement to the length of the sides is solved also within those) is labor intensive.
For example. If triangles of 3,4,5 and 6,8,10 make up the four points in the upper quadrant, then the solution needs to have legs of x (<77), x-1, x-3 and x-5.
Then I'd have to actually do the work to find those sets, and it may be that none are satisfied with the numbers I have, and that the triangles that make up the corners may be larger, like 5,12,13 or something like that.
That's a lot of work! I'll get back to it, but not during regular work hours.
I think I could set up a system of equations to solve that would "do the work" for me, but it would take more organization than I have time for now. I have all of the solutions for the pythagorean theorem where each leg is less than 77.
Labor intensive
Alex Y
Yes, this puzzle seems very computer-friendly, and since my computer "programming" skills are mainly spreadsheet macros, I found solving this one difficult. I took the same approach you have, but made a very stupid error, leading to a conclusion that there was no solution.
David Weaver
well, I've got one solution at 60 length sides so far.
It is made up of triangles with side lengths
er...except that wouldn't put the second two sets of points from the 15,36 in the upper left quadrant.
I'll keep going. Those would've been:
(5,12)*
(55,48)
(15,36)*
(45,24)
David Weaver
I have a solution at 72 now
(16,30), (56,42)
(9,12), (63,60)
Those being the lengths and heights of the various triangles needed to get to 72 total to make the square's sides.
The easy way
Bill Earl
David beat me to the answer. But here is the programmatic solution (in C#)
using System;
using System.Text;
namespace pythagoras
class Program
static void Main(string[] args)
for (int side = 1; side < 80; side++)
TestSquare(side);
Console.ReadLine();
private static void TestSquare(int side)
Console.WriteLine("Testing side = " + side.ToString());
for (int x = 1; x < side / 2; x++)
for (int y = 1; y < side / 2; y++)
double Hyp1 = Math.Sqrt(Math.Pow(x, 2) + Math.Pow(y, 2));
double Hyp2 = Math.Sqrt(Math.Pow(side-x, 2) + Math.Pow(side-y, 2));
if (Math.Floor(Hyp1) == Hyp1 && Math.Floor(Hyp2) == Hyp2)
Console.WriteLine("Side = {0}; x = {1}, y = {2}, Hyp11 = {3}, Hyp2 = {4}", side, x, y, Hyp1, Hyp2);
The complete output:
Bill Earl
Testing side = 1
Testing side = 2
Testing side = 3
Testing side = 4
Testing side = 5
Testing side = 6
Testing side = 7
Testing side = 8
Testing side = 9
Testing side = 10
Testing side = 11
Testing side = 12
Testing side = 13
Testing side = 14
Testing side = 15
Testing side = 16
Testing side = 17
Testing side = 18
Testing side = 19
Testing side = 20
Testing side = 21
Testing side = 22
Testing side = 23
Testing side = 24
Side = 24; x = 3, y = 4, Hyp11 = 5, Hyp2 = 29
Side = 24; x = 4, y = 3, Hyp11 = 5, Hyp2 = 29
Testing side = 25
Testing side = 26
Testing side = 27
Testing side = 28
Testing side = 29
Testing side = 30
Testing side = 31
Testing side = 32
Testing side = 33
Side = 33; x = 5, y = 12, Hyp11 = 13, Hyp2 = 35
Side = 33; x = 12, y = 5, Hyp11 = 13, Hyp2 = 35
Testing side = 34
Testing side = 35
Testing side = 36
Side = 36; x = 8, y = 15, Hyp11 = 17, Hyp2 = 35
Side = 36; x = 15, y = 8, Hyp11 = 17, Hyp2 = 35
Testing side = 37
Testing side = 38
Testing side = 39
Testing side = 40
Testing side = 41
Testing side = 42
Testing side = 43
Testing side = 44
Testing side = 45
Testing side = 46
Testing side = 47
Testing side = 48
Side = 48; x = 6, y = 8, Hyp11 = 10, Hyp2 = 58
Side = 48; x = 8, y = 6, Hyp11 = 10, Hyp2 = 58
Testing side = 49
Testing side = 50
Testing side = 51
Testing side = 52
Side = 52; x = 7, y = 24, Hyp11 = 25, Hyp2 = 53
Side = 52; x = 24, y = 7, Hyp11 = 25, Hyp2 = 53
Testing side = 53
Testing side = 54
Testing side = 55
Testing side = 56
Testing side = 57
Testing side = 58
Testing side = 59
Testing side = 60
Side = 60; x = 5, y = 12, Hyp11 = 13, Hyp2 = 73
Side = 60; x = 12, y = 5, Hyp11 = 13, Hyp2 = 73
Testing side = 61
Testing side = 62
Testing side = 63
Side = 63; x = 8, y = 15, Hyp11 = 17, Hyp2 = 73
Side = 63; x = 15, y = 8, Hyp11 = 17, Hyp2 = 73
Testing side = 64
Testing side = 65
Testing side = 66
Side = 66; x = 10, y = 24, Hyp11 = 26, Hyp2 = 70
Side = 66; x = 24, y = 10, Hyp11 = 26, Hyp2 = 70
Testing side = 67
Testing side = 68
Testing side = 69
Testing side = 70
Testing side = 71
Testing side = 72
Side = 72; x = 9, y = 12, Hyp11 = 15, Hyp2 = 87
Side = 72; x = 12, y = 9, Hyp11 = 15, Hyp2 = 87
Side = 72; x = 16, y = 30, Hyp11 = 34, Hyp2 = 70
Side = 72; x = 30, y = 16, Hyp11 = 34, Hyp2 = 70
Testing side = 73
Testing side = 74
Testing side = 75
Side = 75; x = 7, y = 24, Hyp11 = 25, Hyp2 = 85
Side = 75; x = 24, y = 7, Hyp11 = 25, Hyp2 = 85
Testing side = 76
Side = 76; x = 21, y = 28, Hyp11 = 35, Hyp2 = 73
Side = 76; x = 28, y = 21, Hyp11 = 35, Hyp2 = 73
Testing side = 77
Side = 77; x = 5, y = 12, Hyp11 = 13, Hyp2 = 97
Side = 77; x = 12, y = 5, Hyp11 = 13, Hyp2 = 97
Testing side = 78
Testing side = 79
  good job
40 years ago
Alex Y
I might have done this in Fortran, but no more!
My error
Alex Y
I said I was following the same tack, but made a stupid error. Specifically, I was looking for small and large triangles, then seeing which two pairs had legs that added to the same number. But looking at the small triangles in the first quadrant, I looked only up to size 19 (1/4 --quadrant?!?!--of a number smaller than 80) rather than to 39!
DOH!! Stupid, stupid, stupid.
Good job David and Bill
Re: My error
David Weaver
i almost gave up around that point just out of fatigue.
logical errors on trivial things are tough to eliminate!
