Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Dan Donaldson
This one may take a bit of time. It is a version of the classic "put numbers in the boxes such that all rows, and diagonals add up to the same number.
Here is an interesting version:
The attached image has nineteen circles that have to be filled with the numbers 1 up to (and including) 19. These numbers have to be placed in such a way that all numbers on any horizontal row and any diagonal line add up to the same sum.
Be careful: there are many horizontal and diagonal lines, and different number of circles (3, 4, or 5), nevertheless all these sums have to be equal!
The Question: How should the nineteen numbers be placed in the net?
There are at least 12 solutions, but as far as I know, all of them are simply mirror images or rotations. Perhaps the best way to answer this one is to tell us what the sum for this puzzle is.
Re: Tuesday Puzzle
Sorry
Re: Tuesday Puzzle
Alex Y
But I haven't solved it.
1+2+...+19 = 190 [ n*(n+1)/2 ]
190 total / 5 rows = 38 per row
Re: Tuesday Puzzle
Steven Antonucci
That's what I did, only without the error :-)
Steven Antonucci
I added wrong on a calculator, which has some stick key issues. I think I dropped a 10, which was how I got to 180 instead of 190...
S
Re: Tuesday Puzzle
Total is correct, now for the (a) solution
Re: Tuesday Puzzle
But I already answered "the best way"
Alex Y
I've seen this before, but still don't have a clue how to approach it.
Re: Tuesday Puzzle
What I've concluded so far
Alex Y
Am I right in my conclusions that:
1) Most of the centers of the edges of the hexagon come from 14-19 range
2) Most of the vertices of the hexagon come from the 8-13 range
3) Most of the interior points come from the 1-7 range.
4) At least one of the vertices comes from the 14-19 range.
5) The center point is less than or equal to 11 (and probably 4 or smaller)
Re: Tuesday Puzzle
Here is one answer
Dan Donaldson
You can get others with rotations etc.
Re: Tuesday Puzzle
Solution method?
Alex Y
Any idea for a solution method, short of brute force? Some of the conclusions I drew based on my analysis were accurate, while others were only close, so my approach was clearly not the best. I'm glad you posted the answer before I tired all 19! possibilities :)
Re: Tuesday Puzzle
Re: Solution method?
Dan Donaldson
Sorry, but in this case, it is a problem I found and did not actually do the solution myself. I usually try them myself, but I was running short of time, so I took one that I had already with the answer.
