Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Dan Donaldson
Here is an easy one for you.
Consider the following:
1. The number is less than 500
2. The number is a perfect square
3. The number is a perfect cube
Two of the above are true
what is the number?
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Gary Smyth
Not 1 if negative numbers don't count.
Deadly sins, slightly more than one, nonagon
Re: Tuesday Puzzle
That's AN answer
Alex Y
I suspect there are infinitely many. Another is the square of your answer. There is one smaller than your answer.
Re: Tuesday Puzzle
Re: That's AN answer
Gary Smyth
Fitting the parameters, and starting with a 5,7, or 9?
Re: Tuesday Puzzle
Alex Y
Yes.
531,441 is 81^3 and 729^2.
And the smaller one also meets the conditions, if I understand them correctly.
Re: Tuesday Puzzle
That is the one I was seeking
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Dan Donaldson
An extra just for grins. It is fairly easy also.
There are 5 houses on a road, call them A,B,C,D,and E.
The house numbers for B,C, and D when multiplied together equals 1260
The numbers B,C, and D when added equal twice E's number.
The number of A is half again E's number
Numbers on this road run from 2 to 222.
Re: Tuesday Puzzle
WHICH is the one you were seeking?
Alex Y
I think your post was a reply to mine, in which case you mean the one that is smaller than 729. But it is a little difficult to see that for sure. :|
Re: Tuesday Puzzle
Depends on what you mean by
Alex Y
If what is intended the the looser restriction that these houses are on that road, and thus all five house numbers are >= 2 and <=222, then I have five solutions. If you mean that these house numbers include 2, 222, and three numbers in that range, then it seems impossible.
Re: Tuesday Puzzle
What about 9?
Alex Y
Looking again at this thread, it looks like Dan was replying to Gary, confirming the 729 answer. But 9 is the lowest number that meets the requirements. It meets two of the first three conditions (it is a perfect square less than 500), and it starts (and ends!) with 9.
Re: Tuesday Puzzle
Your first assumption (answer)
Dan Donaldson
What are your 5 solutions ? See if they match the one I have.
A-E: 36,4,9,35,24
Re: Tuesday Puzzle
Re: Your first assumption (answer)
Alex Y
Absent the permutations of B,C,D, I have the following:
36,4,9,35,24 (your solution)
30,4,15,21,20
42,4,45,7,28
54,4,63,5,36
84,3,4,105,56
27,20,9,7,18
33,20,3,21,22
18,60,3,7,36
69,84,3,5,46
And I'm not sure I have them all.
