Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Let's do a thought experiment:
If you take a container of air and double the amount of air in it, the pressure will double also, assuming that you hold the temperature and volume constant.
OK, assume that you measure the pressure in your tire with a standard pressure gauge and it reads 32 pounds per square inch (psi). You now double the amount of air in the tire and assuming that the tire does not expand in any way and the temperature is held constant, what is the new tire pressure as read by your gauge?
Hint, it is NOT 64 psi ;)
Re: Tuesday Puzzle
Re: Tuesday Puzzle
That depends. Are there skis or a surfboard on the roof-rack?
Re: Tuesday Puzzle
Re: Tuesday Puzzle
stp rounded
Re: Tuesday Puzzle
I see.
So, it's parked in front of an ATM.
Re: Tuesday Puzzle
assuming you are talking about the tires of a lunar rover in its intended setting. ;-)
Re: Tuesday Puzzle
  and Alex also
Re: Tuesday Puzzle
Re: Tuesday Puzzle
What is the answer? It's not 64psi, so what is it?
Re: Tuesday Puzzle
Re: Tuesday Puzzle
The pressure in the tyre relates to the vehicle weight.
If the weight doesn't change and the tyre geometry doesn't change the pressure must be the same. 32 psi... (hope that's right!)
Regards
Ray
Re: Tuesday Puzzle
Re: Tuesday Puzzle
I think he was getting at the point that the tire gauge measures not the pressure in the tire, but rather the difference between that pressure and the ambient air pressure, which is a little less than 15psi. So if the gauge reads 32, and using 15 as the ambient pressure, the pressure in the tire is 47psi. Double the air without changing volume or temp, and the pressure in the tire will double to 94psi causing the gauge to read 79psi.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
Hi Alex,
Yes, I think your answer makes more sense than mine.
Nice one.
Regards
Ray
Re: Tuesday Puzzle
