Tuesday Puzzle
An easy one for you.
What is X?
Tuesday Puzzle
What is X?
Re: Tuesday Puzzle
Where the treasure is buried?
Re: Tuesday Puzzle
The 24th letter in the alphabet.
Stephen
Re: Tuesday Puzzle
Vitruvius would have said it is 'X'.
marks the spot
Easy once you see it
I assume. But I still don't. Even considering the answer from Bill, I don't see the underlying pattern or rule. I'm sure it will be easy once I do, but how about a hint or the solution (rationale)?
Re: Easy once you see it
The sum of the top and bottom rows are the same, then the second from the top and second from the bottom etc. Using that rule, the sum needs to be 30, thus X needs to be 10, which just happens to match if you use Roman numerals ;-) (that was unintentional)
