Monday
Monday
Monday
I�m still without a computer�so bad it had to visit a medicine man. So while this computer is used with permission but remote, here is Monday�s trivia. Multiple questions and awarded stars as I will only be able to check back sporadically
1. In U.S. colonial times the hub of a wagon wheel was typically made of an eastern to mid-western tree with habitat from Maine to Texas with spectacular red autumn color. It can reach 90 feet in height, has ovate leaves and small flowers in the spring. That wood is fibrous and difficult to work. So first name the tree and then what was the specialized tool used to turn a heavy wagon hub which could be 1 foot in diameter and 18� long? A simple spring pole lathe will not do.
2. In making Kerosene a hand tool was used to make a �v� groove in a tree. Name common name for the tool.
Re: Monday
Re: Monday
I didn't know kerosene comes from trees. Learn something new everyday.
Re: Monday
Re: Monday
The tree has been decimated courtesy of the Dutch. It used to be the urban tree of choice.
Keroscene is a petroleom derived solvent. I think the question shoulc refer to turpentine which comes from pine trees.
Re: Monday
Dale Lenz
Re:Agree with, John
on the elm for the hubs. Although, all of the elms around here turn yellow in the fall, including red elms. Thanks for the questions.
Re: Monday
Re: Monday clean up
I don't mean to belittle the value of the gold star but they go all around today. I couldn't clean up my own mess. I meant turpentine not kerosene. As Ken called to my attention early, the only tree associated with kerosene is the metal Christmas Tree at a petroleum well head. I tried to correct the question but access was difficult. My error. Turpentine comes from the pine tree. The item I was searching for was a tool called the "HACK". It has a gouge like shaped head standing off of a long handle. The tool is placed about ten feet off the base of the tree and the item is hacked and pulled down making a furrow in the tree trunk. At the bottom of the furrow a cut is made with a tool called a box ax. There at the base the sap oozed down the trunk, collected, and eventually was scraped out into a bucket with a scraper. As an alternative a similar tool called a PULLER was used. It had an arrow head shape and it too made a �V� shaped furrow down the tree.
As to the hub question. The wood I was looking for was Black Gum, also called Tupelo. Elm was also used, so to John and Dale that answer is correct. The lathe was called a �BIG WHEEL� lathe and it was a large diameter drive wheel turned by an apprentice. The wheel was about ten feet in diameter and the close edge of the wheel was located about ten feet away from the lathe and connected by a leather belt to the lathe spindle. It geared the lathe for high rates of spin with heavy blocks of wood. It was also used for mill shafts and large bed posts. It was used for over forty years in Bucks County, PA (Conestoga country).
Examples can be found at the Mercer Museum, in PA.
Re: Monday
Dale Lenz
Re: Thinking, like John
Except our elms turn yellow, and we have most of the elms that grow in ME, I think. Red elm is named due to the reddish color of it's wood, at least I though so. Thanks for the questions
Re: Monday
Monday correction
Awwwwwwwww. Shucks. The only tree for kerosene is the Christmas tree at the well head. I meant turpentine, nor kerosene but got involved in a different conversation when I wrote the question and never noticed my error. Pine trees are the source of turpentine. Still need the tool name. Hint the Mercer museum has one and it looks like a large v gouge with a standoff with the "v" section sharpend blade facing the operatior. It is pulled down the tree trunk making a channel for the sap.
Re: Monday
Ooppps Turpentine, is correct
Turpentine, duh! Long story short. I'm addled owing to likely loss of much data on computer. This computer thing has really tossed me. That plus I had a discussion about furniture finishing while cominig up with question. I wrote Kerocene down without noticing. Turpentine is the item I am after.
