Friday puzzle -- a word challenge
Please don't reveal why I aver this memo has unique looks.
Rather do make your best original theme and post in reply.
Famous Will Shakespeare did secure it:
So true a fool is love, that in your will, ...
Or in Poem LXII:
As I all other in all worths exceed ...
A Supreme Book can do it:
From Ecclesiasticus book LXIII verse XXXII see:
Glorify the Lord as much as ever you can,
for he will yet far exceed.
Or in Gospel by John:
My sheep do hear my voice.
And I know them: and they follow me.
Can you write a sentence (or seven) which keeps faith
under my new paradigm?
Re: Friday puzzle -- a word challenge
Some clarification
The subject line of the original message and the body of the message (separately, but not together) obey a very simple rule. The subject and last paragraph of this message obey the same rule, although this paragraph doesn't.
Your task -- find a rule that works.
A hint (maybe two)
Rules can be hard to use or find but easy to explain or test. If no mistakes on this, rule is obeyed (in subject and text and both).
This one has totally lost me ;-(
Cannot even figure out where to start.
Re: This one has totally lost me ;-(
This phrase fails the test
Phrase two passes
Phrase three fails
Phrase four fails as well
Your subject line fails. But change it to "This one has befuddled this reader" and it works.
More hints
I could have titled this "More clues", but that would have failed the test. I am not making any attempt to comply in what I write in this post, but offer some hints from the exchange where I saw this one. I'll check back tomorrow and provide the very simple rule if no one claims it firest.
A hint from the puzzle's author:
The entire message [in the original post] is a sequence of
words that satisfies a constraint. (*Each* contiguous
subsequence of words in the message satisfies the same
constraint.) The *meanings* of the message and
the individual words are *irrelevant.* My full name
"James Dow Allen" satisfies the constraint, but
"Richard Heathfield" does not, nor does "James Allen".
And some successful claims to have found the rule:
Given your "hint", a puzzle which seemed too hard is now much easier
to unravel. I am writing a short piece to claim to have found a
solution. Am I correct?
He is.
Light dawns (I hope?)
Scary how many hours I pondered this - and how many rules got despatched. I agree with a prior message - It has been a struggle in the making of this reply.
I can't go any further
He found the rule, but violated it once in his reply.
And another one who found the solution, but made a small error in replying -- obeying this rule is MUCH harder than describing it:
I solved it (.....pause for applause.....) too.
But I am finding the proof a bit hard to manage.
I'll try a riddle.
Why did the gnu cross the road?
The gnu wished to see a gnu view.
*almost* ken
Again, only failed the rule once, while this sentence and each sequence within this sentence fails.
still lost
Probably do a face palm when I see it ;-)
Perhaps I see a rule that works here
Re: Perhaps I see a rule that works here
Perhaps you see a rule that works, but here? No.
Re: still lost
probably not. It is VERY hard to see (IMO) or to obey, even if easy to express.
I suspect
that you are like two of the posters in the examples I gave, in that you saw the rule, but made a simple error in execution. Did you mean to say "here"?
I erred in applying the rule.
Perhaps I see a rule that does apply here.
The word here is OK here, but was not where I used it before.
Re: I erred in applying the rule.
Yes, you've got it! And "here" is okay in your first sentence, but not in the whole passage . ("here. The")
Congrats.
Solution
Congrats to Bill for solving this one!
The rule is simple: no two adjacent words can share a letter in common. Pretty simple, eh? But just try to obey it in a sentence of any length, and you will find it very hard. (Use of small words helps, btw)
