Monday --Did you see the moon last night?
I�ve been so wrong in my guesses with recent trivia that I thought I�d post something where I know I�m correct.
This wood has been used for thousands of years for things that were required for daily life be it religious, work, home. It was used by both sexes with women doing the �light� work with the wood collecting and manipulating, and men doing the heavy felling and lifting. But when required, and not forbidden by culture, roles could and regularly were switched. The wood was used worldwide where available, but in one section of the world it was used almost exclusively for everything, mostly because it was the most common, but also because over time it could be adapted to practically every task needed to live.
A few uses were as a diaper filling, aid to childbirth, torchs, slave bindings, weapons, animal traps, food utensils, musical instruments, shelter, personal decoration. Even though it is a wood very old examples exist in museums today and duplicate items are regularly made in order not to lose the skills necessary to keep the "technology" from extinction.
What is the wood? Where in the eorld was the wood used almost exclusively?
Re: Monday --Did you see the moon last night?
I'm guessing that the wood is very aromatic and a couple of varieties grow in North America. There are only specimen trees left in Great Britian and virtually none in Lebanon.
Would this be a wood that Panda's might munch on?
T.
Answer is correct.
John gets it quickly. Cedar is the wood, both red and yellow. Where is the location where it was used almost exclusively? Here are more uses for hints in that area:
Mats
Boxes and baskets
Grave markers
Masks
Rope
Food collection gear
Armor
Blankets
Animal decoys and lures
Ponchos
Building planks and posts
Canoes
Lashings
Fencing both above ground and in water
Wheels did not figure into the applications.
Re: Answer is correct.
The area where another name Tyee dialect was spoken
glc
Re: Monday answer
John gets a star for the wood. Gary gets one for the location
The answer is Cedar. The location I was looking for is not ancient Egypt which used a lot of it or the Mid East, but the Northwest coast from Washington State up the coast through British Columbia to Alaska. These were the homes of the Haida, Salish, Kwakiutl, Tlingit, Timishian, Nootka, Quileute, and Makah...
Traceable history there is 9000 years old. Time has taken much of the old growth but a few live cedars today are dated at 1000 years. Those trees can have a base exceeding 14� in diameter and be 230 feet tall. Cedar is exceedingly versatile. It has a loose cellular structure that has better insulating qualities than hardwood. It is light weight, straight grained, is easily cleaved and split, and can be beaten to a fine thread like consistency. Cedar can be steamed, and bent. It can be woven so tightly it can serve as rainwear or split and hammered soft and fine so it allows urine to pass and keep a baby�s bottom both dry and warm. Textile study people often win grant money to learn a particular weave pattern/technique as the original cedar objects are still around, but the way to make them has passed or is dying every day. Cedar contains its own fungicide (thujaplicin) which can allow a fallen tree to be used even 100 years after it has fallen.
The log, bark, roots, and withes (branchlets) can be used for various things. The flexible withes can have a tensile strength of 10,000 lbs p.s.i. twice that of cedar wood planks and 30 % greater than Douglas fir. The inner bark is famous for its cordage making qualities and examples vary from thin lashing twisted �thread� to 1 �� braded rope used to keep whales from sinking after being harpooned from the hand hewn cedar boats, driven with cedar oars and cedar mat sails, manned by humans dressed in cedar garments, using lightweight cedar spears. Rope lengths lashed together horizontally around the torso also made an effective armor for warriors. One of the unusual uses for cedar was as a strong flexible line that was looped around an almost born child (breech birth?). The mother helped her birthing by bracing her feet then pushing away while holding/pulling on the line in a pulley style arrangement (around a post) to assist in moving the child out of her womb. Strong women these. Many tribes of the Northwest were raiders and high ranking leaders regularly had a dozen or so slaves. Slaving, which was a brisk business throughout the region (but rarely discussed) used cedar bark rope bindings and enclosures.
Totem poles are cedar. There are few poles permitted these days but with the right connections, and cash, it is still possible to get a 2 ft wide board nine feet long. Next time you look at a pencil remember too that cedar was selected because it is plentiful and easily machined but also because it can be chewed safely.
References are: �Cedar� by Hilary Stewart;
