Monday, Start anew
Monday, Start anew
Monday, Start anew
While we are still working out Alex's Friday question here is Monday's. With the harvest moon over and the weather getting colder old Route 40 (National Road) has been having lots of flea markets along it length. Highlights have been visiting some covered bridges, tool hunting, but also the "Z" stone bridges of the original path. There were three reasons provided why a bridge was built in the form of a "Z". One reason provided was to honor pioneer Ebenezer Zane which seems a bit much to me. Todays trivia is to relate the other two reasons. Keep in mind that the National Road was a road based on wild game, then indian, then military paths. For the final version it was a wholy government project with engineers and planners and transport all involved.
Re: Monday, Start anew
Since this is a wood related site, I'm going to guess that logging roads/rail-lines had something to do with road placement(?).
Because the bridge engineers were mostly French and they would tell the workers to "build zee vooden bridge"?
Tom
Wood was a stretch on this one.
It has to do with the traffic on the bridge which was in part wood.
Could it possibly be that building a bridge squarely across a river or stream was easier and less expensive than building it at an angle to follow the approach and departure of the road?
Fred
Under cloudy and clearing skies in Eastern Missouri
Not my answer...
but I've seen or heard about that. If you have a source let me know.
I might know where to look...
But I can't give an answer, 'cause I had to look it up. Eric Sloane?
glc
Hint
Consider the traffic over the road. Earlier I wrote about the wood connection. I was probably not clear. Wood has to do with the transportation using the bridge and not always the bridge. The bridges I saw (the ones that remained and were preserved) were of large dressed stone. Also "Z" bridges were not long (perhaps 30 yards) as they typically only went over a brook or creek. Additionally, since this was a National Road you have to take into consideration the engineers thinking. I'm thinking that they used the same reasoning as the offset paths of Japanese gardens.
Re: Hint
They did it for a Zen experience? ;-)
T.
Ssssssss
As I understand it a different letter of the alphabet was used to describe the view from space of the bridges.
Lee
Re: I might know where to look...
That would be my source, as well. "A Reverence for Wood" notably.
Fred
Re: Question and easy answer
Question? Are they having flea markets on Rt 40 too, or are you confusing it with the country wide flea markets on old US 30 in the summer?
Easy answer to your question. Since they already had built the "Y" bridge in Zanesvill, OH, all they had left that they could build was the "Z" bridge.
Re: Monday answer
Frederick get credit today. He came closest for one of the sources. Small gold star.
Reason one: The bridge was named for Ebenezer Zane, a worthy pioneer, who, in fact, after 1796 Congress authorized to cut trees and opened the way as far as Kentucky, but this thought was foisted on us by a docent who was from Zanesville, Ohio. It could be true but one of the bridges I saw was near Washington, PA thirty miles east from Wheeling, W.Va (but dated circa 1810), where ole� Eb started his work.
I favor one or both of the other reasons.
Reason two: A zig in the bridge assured that traffic slowed down (usually in a valley or swale) and could not be run easily at high speed�and impossible with a wagon and team. Bridge surfaces could be dirt or plank. In all weather it paid to be careful and go slowly. Japanese gardens have bridges with offset stones too. They are placed in such a way that one must slow down and side step or change direction and thus allow a moment for thought on the beauty of the garden. That wasn�t the idea for the National Road bridge, but it did have the same effect. A wagon team did about 15 miles a day. A freight wagon could get Baltimore shellfish to Pittsburgh before the recipient was poisoned, but care on the bridges was better safety.
Reason three: At the time there was the consideration by the teamsters of using 40 foot wagons or even tandem wagons. The National road was hilly and while not so awfully difficult for a team of four to six, the roadbed had to be maintained. A typical wagon was fourteen feet at the bottom of the bed and sixteen feet at the top and carried six to eight tons--half that if the trip was long and team food had to be carried. The bigger wagons would have carried much more. If a loaded 40 foot �super� wagon used a bridge the bridge could be overloaded. The zig/zag prevented the larger wagon from passing without the wheels hitting the bridge sides. If a tandem was considered, the process of unhooking one wagon, taking one across, parking wagon one, disconnecting the team, getting the second wagon, reconnecting, crossing, reconnecting both wagons, was considered a sufficient enough pain to prevent a wagon train. The offset prevented overloading of the bridge and it also kept the surface in better shape.
As an aside, in the early days, it was the responsibility of the road builder to provide stepping stones and a shallow crossing point with access to the road without using the bridge. It also allowed for the team to get some water while on the move. Some say this was the start of calling a person �a stick in the mud�. Around here similar fords are still around in some places, and on the weekends I�ve seen cars pull off the highway drive down to the stream and get washed. I never thought that these old well worn turnoffs might have been part of an original road plan.
The horses used to pull these heavy conveyances were a cross between a Flemish draft horse and an English breed chosen for size and endurance. They were most often black, and occasionally a bay or dappled gray, stood five feet tall, were remarkably docile, and cost between $170 and $200 in early 1800�s dollars. They were decorated with fancy pom poms and other elaborate head and forelock gear and put on quite a show as they marched through towns and villages. If the wagon made it safely without help from another driver he arrived �with his bells on�. Conestoga horses were finely bred and named Conestogas after the area in Pennsylvania where they originated. Sadly the breed is now considered extinct.
What eventually did the �Z� bridges in were the winters, a lot more people traveling west of Pittsburgh, and railroads. In winter snow built up over the sides in the center of the bridge and made them impassable with wheel or sled. Too many people were stranded in the winter owing in part to the bridge design and that was not good for horse, wagon, freight, people or politics..
Some info came from the docents between Uniontown, PA, Wheeling, W.VA., and Zanesville, Ohio, on Route 40 with some support from books by Eric Sloane and Edwin Tunis. The web, with the subject of �Conestoga� also gave or confirmed info.
Addition:
Gary gets credit also. My error. Eric Sloane is certainly one of the sources. Gold star also.
Dale, my excursion was on Route 40. Billed as "National Road Days" or something of the sort. The stopping places were spotty and the pure junk unbelievable as a sale item. I think some sellers brought out the items last year and didn't want to take them back to the barn so they stayed out in the weather. Rust never sleeps. And to be sure, there were the lawn planted painted wood kissing dutchmen and tulips, hundreds of Beanie Babys, dishes, fudge and bread. etc. I've not been to Route 30 sales. That road goes north from me towards East Liverpool, Ohio, then across the state. Closest I get is a few miles on 30 to Rogers, Ohio Flea Market on Fridays, once or twice a year.
