Do not open til midnight ;-)
Posting a bit early because I will not be around for most of the day tomorrow ;-)
Replace the letters with numbers to make it make sense:
Twelve
Twelve
Twelve
Twelve
Twelve
+thirty
ninety
Twelve
Twelve
Twelve
Twelve
Twelve
+thirty
ninety
Re: Do not open til midnight ;-)
5X12+30=90 Yeah....it can't possibly be that easy.
T.
My thoughts exactly!
I saw the same solution had the same thought that it couldn't be that easy....
Lee
I think each letter stands for a different number - like a substitution cypher.
Lynn
That is correct. Each letter stands for a number.
Is case significant?
For example, is the 'T' in 'Twelve' different from the 't'(s) in 'thirty'?
4s 194s 41?
I think not
Since there are ten letters without considering case.
And if it is...
Was there a way to get it w/o trial and error?
I was able to
But I still had to use trial-and-error (getting the answer on the 4th case tested).
Unless I got it wrong... :-(
not significant
Answer
130760
130760
130760
130760
130760
+194215
848015
Not sure how to read Alex's answer. He will have to tell if it is correct. Also, I am not aware of any way to totally deduce all of the numbers without some trial and error.
Re: Answer
That's the answer I got.
If I did it right (that's a big if!), I used the same letter/numeral cipher to the extent possible to ask "Is this it?"
Good, but hard, puzzle.
