Monday
Monday
Monday
Try to remember before looking for confirmation. Before mechanical means took over, about this time of year farmers started to prepare for autumn. This was a hand operated item related to a tool first recorded in 1500 B.C. Then came minor �but progressively efficient improvements but not until the 1800s did this item appear. It quadrupled the output of a typical man�s/women�s labor and even up to � times more for a traveling pro if the farmer was willing to pay $2.00 a day�sun up to sun down and hearty meals. The center of interest in this agricultural tool was the midwest. According to the Net, patents for similar tools during the decades from 1820 to 1930 totaled 50, the first issued in 1823 to a gentleman in western New York state and the last issued in 1924 to a gentleman in West Virginia. The peak of innovation was in the third quarter of the 19th century. What is the tool? Just to let you know I saw one at a estate/farm house sale recently and it went for about the same money as when new. Less than $10.00.
Re: Monday
Re: Monday
being this late in the day, I'll hazard a sythe(sp?). I have four of them picked up in farm auctions over the years.
John
Re: Monday
Re: Monday
John's answer makes sense for the time of year-harvest. Is a sickle(sp)the same type of thing ?
Re: Monday
Re: Monday
Don't know the answer, but to answer Don's question a scythe is a longhandled tool usually with two handles and a long banana shaped blade used generally to harvest grains. To give you a mental picture it is what the Grim Reaper carries. A sickle is a one handed tool with a much more curved blade. It was also used to harvest grain but my guess is the scythe would be more efficient.
Re: Monday
Neither Scythe or Sickle...but
you all are more than half way there technologically. The sickle has been reported since well before Christ's time. The scythe was newer and its main advantages were that the tools blade was wider, longer, less curved, the handle two handed, and most importantly a person could move through the field swinging in a fluid motion standing upright and not bent over. It saved the farmhand's back (as if anyone cared), and the person could get through two acres of cutting per day.
Neither are the tool I'm looking for, but all of you are closer.
Re: Monday
I could be trashed
for giving out the answer this soon..
Lee
Re: Monday
Re: I could be trashed
Of course if I could spell it would make more sense. Thrashed....
Re: Monday
This is guess
I'm not sure what the tool is called but what I am thinking of is a hook in a wooden handle (similar to a rebar wire twister) used too twist grain straw to tie the shocks togather before threshing. I can guess these twisters being about $10.
glc
Re: Monday
Re: Monday
I would have guessed grain cradle, but if you saw one in decent shape go for $10, that would be a steal. They're generally a little more expensive than that in the antique market..
Re: Monday
You're a step ahead of what I'm looking for
Re: Monday
Ding, ding, ding! Answer
I wish I had spelled "you're" correctly from my last post. Drat!.
Dale gets the gold forehead star today. What I was looking for is a grain cradle.
A grain harvest consists of cutting, gathering, drying, thrashing. The tool I�m looking for is a grain cradle. It works like a scythe to cut the grain, but the grain cradle has four to six curved wood �fingers� in the same approximate plane as the blade. A scythe�s motion cuts but scatters the cut stalks. In the process much of the grain is knocked from the heads and remains in the field. When scythe cut grain is gathered it is laying in all directions. It is then generally is raked and placed in piles, and if one is not careful of how it is collected, of moisture content, and where it is stored, cut grain can generate enough heat in this piled up condition to catch fire. This makes animals who expect to be fed in the winter very angry. The cradle is worked like a scythe but the multiple fingers of the cradle catch the cut grain and result in having most of the stalks collected with the heads in the same direction. It also loses fewer grain heads. This makes the grain sheaves collected in the cradle or turned over in the field easier to tie off using a length of stalk or string. It made thrashing much easier because the cuttings all faced the same direction. Later the stalks could later be cut back using a straw cutter/guillotine and the grain heads thrashed more efficiently as opposed to flailing a pile of cuttings with far more straw than grain. With a cradle again according to the net, once a rhythm was established and the blade sharpened each quarter mile, four or perhaps a little more acres could be cut by a pro in a dry day. I searched the internet to find a video of a cradle in action cutting and piling stalks, but came up empty. There are many pictures of cradles on browsers under �grain cradle� for those that have further interest. A grain cradle is an awkward tool to store because it is wide and the handle is at an angle to the cutter and fingers. As a result a grain cradle is less often cared for(the finger length, smoothness, curvature is important) and therefore is less often seen than a scythe these days. And yes, Dale, even though the sale was well attended the cradle went for, I believe, $8--down from the $10 on the tag.
Re: Monday
Huh?
What are you talking about. The spelling looks fine to me ;-)
Re: Monday
sharon in topanga
Re: Huh?
The message having
You're a step ahead of what I'm looking for *NM*
used to say
Your a step ahead of what I'm looking for *NM*
I don't know how it got fixed.
Re: Monday
Re: Huh?
A dandy deed, if I'm not mistaken!
Re: Monday
Thank you. A good editor is worth
a thousand words. Dan-gerously scary.
Re: Monday
