Tuesday Puzzle
Tuesday Puzzle
Tuesday Puzzle
Another number type of puzzle for you. ;-)
17 (35) 19
22 (46) 26
31 (65) 37
44 (92) 52
What are the three numbers in the last row?
Re: Tuesday Puzzle
OOPS
That is what I get for trying to do anything that takes any thought at that time of the morning. Fixed errors in the post, check it again. Sorry ;-)
Re: Tuesday Puzzle
Re: Tuesday Puzzle
All three numbers share a common digit.
The second and third have two digits in common.
Re: Tuesday Puzzle
Re: Tuesday Puzzle
I don't know the answer but once it is posted I'll be off to the gas station to buy some lottery tickets.
Tom
Re: Tuesday Puzzle
One answer
is 61 (127) 71
But I suspect that is not what you had in mind, since it doesn't depend on any relationship between the columns. I just continued the second differences of 4 in the outside columns and negative 8 in the inside column.
Re: Tuesday Puzzle
Correct. The actual numbers are in Alex's post below. Another way of seeing the pattern involves 2,3,4,5,6,7,8,9,10 and 1,2,3,4,5. Can you see it?
Re: Tuesday Puzzle
;-) see reply to Bill's answer above.
Re: Tuesday Puzzle
Re: ;-)
Yes, the pattern I observed was:
Non-parenthesized numbers increase by successive numbers starting with 2. e.g 17 + 2 = 19, 19 + 3 = 22, etc.
Parenthesized numbers are the sum of the non-parenthesized numbers in the row, minus the row number. e.g. 61 + 71 - 5 = 127.
